Hi All,
Recently had the 40k service done. Got the service people to change the under bonnet fuel filter at my cost, they were reluctant like not required till the light comes on and on and on.....
Post service the vehicle runs better, more responsive and while trying to find and answer as to why (not that I was not happy that it was running better and clearly more responsive) found the this thread where the use of winter fuel is known to clog the filter especially in UK? Apparently like every where else in the world everyone got informed but hey who cares about people down under? As we are coming up to winter again this may cause problem again.
https://www.landcruiserclub.net/comm...-power.136774/
"The new D-4D engines (across the Toyota range) have a new type of fuel filter which gets clogged by the additives in the UK winter fuel. The solution to replace the filter housing with a heated housing to heat the fuel. There is also a heat exchanger being installed at the tank which heats the out-coming fuel with hot return fuel from the engine."
Anyone else experience such a change or similar change? Mind you the servo that I fill from has winter diesel for a few months in winter.
TIA.
TIA.
