Originally posted by AussieAndy
View Post
Why would you have Warranty issues with the Racor fitted Post? Is it because as David said above that you have no way of knowing if it is blocked with debris (or water when driving )?
Please excuse my ignorance but is the clear plastic bowl underneath empty in operation and fills with the water only when detected or is there diesel in their all the time and the water is then added to it when detected/separated ?
Have you added a length of plastic tube to the water release 'nipple' underneath to direct the waste away to a more suitable spot rather than have it spill on to the guard directly underneath?
Can you while using AMTS 's bracket use the water release and empty any collected water or do you have to unbolt the Racor until from the bracket to do this operation?
A different way of dealing with any collected water was mentioned to me by an Enzed manager. He has a Racor fitted and said you can get an optional extra part that automatically releases any water trapped. It has a sensor that releases water when it gets to a certain level. You can be driving along and it just does it - you wouldn't know. It needs 12V power to it. It just screws in to the bowl underneath. Cost I don't know.
Whether you have enough room with AMTS's bracket I am not sure as there is not a lot of clearance at the bottom.
Whether this is as good an option as David's idea above I wouldn't know.
I welcome your thoughts once again
thanks
David
