We seem to be having the exact same problem with our late model 2012 gxl prado. We have only ever been able to fill 135 litres and that's after we've been on 0km for a while. To fill this much takes forever because as you describe, it bubbles, gurgles and then goes down. Did Toyota ever acknowledge a problem?
Diesel - refuelling problem
Originally posted by Ozboundx3 View PostWe seem to be having the exact same problem with our late model 2012 gxl prado. We have only ever been able to fill 135 litres and that's after we've been on 0km for a while. To fill this much takes forever because as you describe, it bubbles, gurgles and then goes down. Did Toyota ever acknowledge a problem?
Try refuelling using BP Ultimate Diesel.... I've never been a fan of BP as their prices are always dearer then shell/caltex, but for time sake, I now try and always use BP Ultimate as this is the only Diesel that I've found that doesn't foam up so much. Shell/Caltex all seem to foam up and the last 5/10ltrs takes ages... Where there's no BP Ultimate, then it's either BP/Shell/Catlex & just fill up slowly.....
135ltrs for what sort of distance ??[I]cheers..... Rob (macca)[/I]
I fill with Caltex Vortex Diesel (due to work fuel card) that has an anti foaming agent in it apparently. I always use the hi-flo pump and jam the fuel tank cap in the handle. Seems to run it around 80% flow rate and clicks off when full, works well and no foaming. When Caltex had the previous diesel it used to foam like a bubble bath.[url=http://www.myswag.org/index.php?topic=12264]My Prado[/url]
Originally posted by D4D View PostI always use the hi-flo pump and jam the fuel tank cap in the handle.Dave
We have filled up many times with Caltex Vortex and have found it still foams up just as bad....... Same with Shell, so unless the Servo is false advertising and actually selling lower std diesel, then for us BP has been the only one where I'm not standing around for 10+mins trying to fill the Prado up to 100% mark......
Originally posted by D4D View PostI fill with Caltex Vortex Diesel (due to work fuel card) that has an anti foaming agent in it apparently. I always use the hi-flo pump and jam the fuel tank cap in the handle. Seems to run it around 80% flow rate and clicks off when full, works well and no foaming. When Caltex had the previous diesel it used to foam like a bubble bath.[I]cheers..... Rob (macca)[/I]
Originally posted by D4D View PostOK it seems I jinxed myself. Filled up with 160L tonight and just as it stopped it burped and blew diesel at me and all over the Prado2012 Pearl White VX, 3.0 Litre D4D Auto, Wynnum 2.5T Tow Bar, OME Lift, TJM Airtech snorkle, TJM diff breathers, Redarc EBRH, Projecta DBC100K, Lightforce XGT, EBC Nudge bar, Custom Recovery Points, TG150, ARB compressor, Pioneer Platform, Kaymar #K7123 /CDQ2195, 697 A/T's, Tin's DC trans cooler, MaxTrax on TraxRax, TJM DBS, Piranha Tray...
With my old 150 (2009 model) I found the different types of fuel gave different results. The fuel from the big W gives more problems (green bully stuff) and I had significantly less problems with Vortex Diesel.
Picked up a new 150 in March this year. Fitted the long range tank and it fills to the top every time (except for the green bubbly stuff). I got under the car and checked all the fuel lines. Compared this to my old 150 and you guessed it, two hoses at the rear tank were reversed. This probably explained why my old 150 would not fill correctly. I checked my old 150 with the fuel tube assembly diagram and found it is not quite correct or I am not interpreting the diagram correctly. the three hoses (rear tank, drivers side) are not one for one as laid out on the car and fuel tank. I don't have any issues filling my 2013 Prado unless I use that green bubbly stuff which seems to generate foam and then the fuel economy suffers. Vortex fills to the top every time.
Much happier with the new 150, fills every time and the hoses were different when comparing to the old 150. Maybe some others could have a look and report what they find.
Let me know if you want a photo, not sure if I can get one as the long range tank pretty well covers all the hoses.
Nifty
After seeing brother suffer for a few years with this problem my 120 decided to take up the challenge and started doing it to. Put 50 liters in then bubble bubble for 90 liters until full.
Long story made short it is the flap in the filler on the front tank. What happen is the fuel flap in the front tank gets a little sticky and stays shut long enough for pressure from the rear tank taking fuel puts slight pressure into the front tank via the bleed line. This then puts slightly higher pressure in the front tank than the fill line pressure. This holds the front tank flap shut preventing any fuel entering. The vent line is now full of fuel and the vent point being the top of the filler keeps this line full and prevents the front tank venting.
So to the fix. - When low on fuel remove the filler to the front tank and bend a piece of wire so it holds the filler flap open. Now when filling the front tank will fill first always as the rear tank flap will hold just enough. When the front tank is full the fuel will have enough weight to open and fill the rear tank.
Rusty.08 VX D4D, Lift, Safari Snorkle, Trailblazer Fridge, Custom Storeage System, BFG, ARB Safari Bar, Wife, Kids, Codan NGT HF Radio, Debt.
I was just wondering if only filling the tank to 1/2 full regularly may cause the flap to stick die to lack of lubrication by the fuel. do any of you have any experience with this?
Just a thought.Greg - 08 D4D Prado,
Its not the fuel, just the pressure increase from the incoming new fuel. If for any reason the pressure in tank in higher the fill line the flap will stay shut. Only when the rear tank gets fuel first.
Up until this i could hear when the front was full and started on the rear. Have not had any issues filling since.
