Range when fuel light comes on?
  • Range when fuel light comes on?
    One of the problems with having the 150L fuel capacity is its hard to confidently use it all due to uncertainty at the bottom end of the fuel gauge.
    does anyone know what the actual usable volume of the fuel tank is?
    My fuel light came on yesterday and filled up this morning. I drove about 60km with the fuel light on before fuelling up. by this stage the range on the dash was showing 0km and I squeezed 131.5L into the tank
    My ave L/100km on the trip computer is around 13L/100km and i did just under 1000km so that seems pretty accurate, so in theory i had 18.5L in the tank which should give a further range of 142km, and knowing that i drove 60km with the fuel light on in normal driving i should have 200km range once the light comes on, and a total range of about 1120km
    What is the experience of others?
    For interest my car is 2014 GXL 3.0L auto.
    Mine comes on when there's between 20 and 30L left.
      is your average normally that high? mine is the same as gxl_d4d , if you want to find out for sure take some spare fuel with you and drive until it misses(not recommended tho)
      you trip computer is the average since it was last reset too , only a guide really, might be worth resetting it
        I definitely would not deliberately run the fuel tank dry, or even “drive until it misses”. (Sorry Bear63, I know you already said not recommended). The fuel pump operates at extremely high pressures and fine tolerances, the diesel fuel lubricates the pump as it goes through. To have it running dry, even for a short time, is inviting disaster. Wil, I’d be more concerned about your rate of fuel consumption. I’ve got a 2015 2.8L GXL auto with bull bar, roof racks, always tools and recovery gear, fridge etc and I average a shade over 10L/100km.
          Yeah - its always been a bit thirsty, but with the extras i am not helping it any.
          The fuel usage is a bit less then what i have said earlier as it is running 265/70/17 so if numbers are adjusted for that its a bit better.
          adding to the usage though is:
          larger tyres
          All terrain tyres
          2in lift
          bullbar
          roofrack with awning on one side and fishing rod tube on the other
          smart alternator function off for full charging of auxiliary battery
          fridge always running
          based in Darwin so AC always flat out
          high ambiant temps reduce efficiency.
          that said Darwin is pretty flat and not as much stop start as other cities.
          I might do some testing over the next little while and see what taking off the roof rack does.
            Wil do you do much high speeed traveling ? over 110 kmph?
            could be your sitting on 120 - 130 kmph a lot more than the southerners
              Nope - 13L/100km is standard for the usual running around and work commute which is about 20km mostly at 100km/h.
              a couple of mates get the same out of their prados with much the same outfit, i just figure its normal. My other car (which i have recently sold) was a holden colorado and it used to average 10.5L/100km but it sits lower so catches less wind drag, its lighter, manual and doesnt have constant 4x4 - i would like to spend less on fuel, but i didnt actually think 13L/100km was too bad.
              anyway, back to the original question - has anyone run their car to empty and how much diesel did it take to fill?
              Wil
                The most I have put in my 2018 Prado is 134.33 L. Fuel light was on and had been for a while. I had done 1433 km on that tank. From what I have experienced I think it's safe to say there's 20 L left when the fuel light comes on. Generally my after refuel consumption on the computer is about 10L/100km or under so I would say about 200 km left. Hope that helps.
                  The owners manual, page 547, says that when the fuel light comes on there is about 22 litres left in the tank.
                    My 150 series tanks are supposed to have a combined capacity of 150 L. I refuelled after the fuel warning lights was running for a short time, taking about 130 L. So if the Manual is saying about 22L remains as the light is activated, that matches pretty well to my recent experience.
                    2019 Prado GXL 2.8L Diesel
                    2022 Jimny too
                      Hi gxl_d4d,
                      Just in case you missed it, I responded to your message about ATF temperatures. Hopefully it transmitted ok.
                      No problems.
                      regards.
                      2022 Jimny too
                        I don't even know what to recommend
                          I had a problem with the gauge, and it did not come to one by 2 bars.
                            larger tyres
                            All terrain tyres
                            2in lift
                            bullbar
                            How do you do this, if you dont mind sharing
