Add a hire car to the costs. If you are left without a car, it will be approved in a court of law. Basic action in this situation.
You can do oil analysis on much less. Go to your local cavpower / CAT store. they sell a small bottle that's under 250ml to test oil from memory.
I would be using Toyota to do the mechanical check. Reason being they will likely be most expensive and will be all genuine parts. They will force a long block as the solution to repair most likely.
If it goes to court, Toyota will have the best standing as a witness, rather than any average mechanic.
