Hi all . Coming back from a trip after escaping covid ridden Melbourne , nearly home on the freeway in the rain , low fuel light starts flashing . Fuel gauge showed 1/4 full and range showed about 350k . Put some fuel in at the first servo , and light went out , but not good for peace of mind . Assuming fuel is not transferring from rear to main tank . Changed the inter tank filter which looked fine . Did some reading and
some thinking .
At the fuel pump relay on the fuse box , there is 12V on on side of the relay contacts . No resistance to ground on the other side . Is there a direct connection between the relay and the pump ? If so this would suggest a wiring or pump fault .
Does anyone have access to a cct diagram of this part of the wiring so I can confirm this ?
Cheers Dave
some thinking .
Cheers Dave
