need some help, no engine light, but Mode $06 detects errors
  • need some help, no engine light, but Mode $06 detects errors
    Hi, i own a 2014 Toyota Land Cruiser Prado, exact model is TRJ150L-GKPEKV 2TRFE 4FC. I am located in Middle East. This car is very common here. I am the third owner of this car. I got error code related to heated oxygen sensor in the past and i changed it and all error codes went away. But whenever i check with torque pro testing using mode Mode $06 i get test results as followed. Its been 3 months since i replaced the heated oxygen sensor. I am posting the full loop of the test result. Drive is ok. There is more than usual sound from exhaust system but nothing else. I am setting up real time server for torque pro logging, but i have no idea how to interpret.
    Test report:
    MID:$01 TID:$8e
    - O2 Bank 1 Sensor 1
    Test incomplete or dependant test failed
    MID:$01 TID:$91
    MID:$02 TID:$07
    Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
    MID:$02 TID:$08
    Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
    MID:$02 TID:$8f
    what could be the problem?
    Hi, i own a 2014 Toyota Land Cruiser Prado, TRJ150L-GKPEKV 2TRFE 4FC.
    Try clearing all codes and then see how many come back.
      i have no codes. ECU search show no codes. This information is from torque pro testing (Mode $06).
      I have no check engine lights.
      EDIT: I used another software, it does not give any error, and ECU detected more codes, all are cleared now and nothing came back so far.
      sawfankhan
      Lurker
