150 GXL fuel tanks
  • 150 GXL fuel tanks
    Hi everyone, I thought 150 series only had one fuel tank and that it was smaller than in the 120 series. A few of the guys were crawling around under the car at work the other day and noticed that there's two.
    Does anyone know the sizes of these two tanks and I assume it gravity feeds from to the other.
    Dermie
    It does have two tanks, but they act as one tank, in that one feeds to the other, unlike the previous models, where you selected which tank to use. you could also choose which tank you used to fill, whereas now, it only has one filler tube. i think the tank sizes are 83 and 67? but I may be confused and wrong.
    2011 150series GXL
      Cheers Wooley
        The 90 series were selectable and filled seperatly, the 120 acts as a single tank. Not all 150's have the 2 tanks though, only the 5 door has both, the 3 door only has the 1 tank. Total capacity for the 150 series is appropriately 150lts.
          Spot on Wooley for 5 door tanks sizes....
          Copied directly from Toyota's Specs for 5 door model: "Fuel tank capacity: 87L main; 63L sub tank"
          Gerard
          [u]2011 GXL D4D Auto[/u]
          Reshaped bash plates and side steps along with numerous scratches and minor dings all with great memories!
          Cooper ST-Maxx's, Polyair Air Bags, Engel 40l, TJM Nudge bar, ARB Deluxe Roof Rack. Tambo CooperXT Camper.
            Thanks for the help guys. Dermie
              Hi Folks
              Not sure of you have noticed this yet, but when the guage and trip computer show empty, the most I have been able to fit in is 125lts, therefore at my current usage there is about a 150-200km reserve hiding in there.
              Regards, Richo.
                Hi Richo,
                I reset my tripmeter when it tells me I have 0km to empty and travel at least 50km (I stretch this to 100km on the hwy) and still only put 145 litres in. This is the petrol not the diesel.
                Regards,
                Macca
                  Richo, I have not gone that low yet as i usually refill at half a tank (cheaper) but from what I have read the actual reserve (needle says empty) is rather huge possibly more than 20ltrs
                    From what I read somewhere else on this forum the fuel is circulated through both tanks continuously and there is a cooler in there somewhere, that system in itself would use up some fuel. Most I have ever put in is 141ltr, be interesting if anyone ever put more in.
                      137ltr's of diesel put in tonight, computer says 0km left about 40km ago. Going on this there could probably be 150km in reserve.
                      [size=1]2011 GXL D4D Auto | ARB Deluxe winch bar | Bilstein/Ridepro platinum lift | MT ATZ P3's | Dick Cepek Torque rims | Airtec snorkel | Lightforce Genesis 55w HID | GME UHF | 55w HID high beam | Rhino Rack bars & Cage | ISI extreme rack | Dual Optima Batteries | Milford MXV-70 cargo barrier | ARB onboard air | Prodigy P3 | Drawers & Black widow fridge slide | Waeco CF-50 | Kaymar rear bracket and LED light | EscapeGear seat covers | Sandgrabbas and more...[/size]
                        Someone pushed it to empty and got 175km, but that would be on flat ground. Push it on a hill and you could be pushing the car up the hill instead of your luck.
                        Stephen Bloomer
                          There should be 22ltr's when the fuel light comes on. The scangauge backs this up. So @ 10L/100 you should be able to do 220kms. I have done about 200kms from when the light come on and scangauge said i had 4 Lts left. I try not to get that low.(servo was shut on the way home one night, so it was steady driving)
                          2010 GXL D4D 6Speed
                          Tojo Towbar, Cargo mat, 80L Waeco, ScanGauge II, ARB 2nd battery cradle, Redarc, 75aH, Ironman commercial bar, Homemade scrub rails, 220mm Roo lights, Bigger mud flaps, Uniden UHF, RMW seat covers, Homemade Roof rack, Dark window tint, Sony headrest DVD players, 2 Kids seats with food and drink everywhere..
                            I waited until my light came on recently, drove about another 50 Kms to the next fuel station (yes I did have a Jerry on board)....and put in 139 Litres.....so I don't know if it has a hell of buffer or about 10 litres you can't use...hope not am doing the Simmo in July and am banking on having at least 145 to use with a Jerry to give me a buffer, that's say 165 and they say the average is about 137 for a 3 litre diesel.
                            150 Silver Diesel GXL Auto with ECB Bullbar, Toyota Factory towbar, Black Widow Drawer system with Fridge slide and cargo barrier, GME UHF 3340 Radio, Waeco 50 Litre Fridge, Rhino Racks and Rhino Basket, ARB Awning, IPF XS Spotties, ABR Sidewinder Dual Battery system,Airtec Snorkel, Bilstien Shockies, King Springs, Poly Airbags and BFG A/T''s. Now towing a semi offroad Lotus Freelander 18.6 Van, with all the bells and whistles.
                              Just curious here in regards to your ScanGauge..... When refilling, what WAS your Percentage Difference (in fuel) when u 1st started using the ScanGauge and do u find this varies when towing?
                              rob
