Hi all, anyone get a slight crunching noise as the transmission goes into low range? Is this normal?
Slight crunch noise entering low range
150 GXL V6 Auto. BFG AT 275/65/R17, ARB Deluxe Winch Bar, OME 2" Lift, Firestone Airbags, Dual Batteries, GME UHF, Rhino Sportz Crossrails and Platform Rack, ARB Awning, Redarc Brake Controller, Rear Drawer System, Safari Snorkel, New Toyota Mudflaps, Kaymar 'Wheel on Door' Bracket, ARB Under Vehicle Protection, IPF 900XS Spotties, Allied Hammer Wheels. Disclaimer - I am an ARB employee. [B][URL="http://www.pradopoint.com/showthread.php?17348-Sam-s-150-V6"]Buildup Thread[/URL][/B]Tags: None
Were you eating a Jatz cracker at the time? Thatll do it.sigpic2" King Springs, Ironman Foam Cell Shocks. 17x9 Dick Cepek wheels with 275/70/17 Maxxis Bighorn 762S. Ironman Deluxe Bullbar. Lightforce 240 XGT Lights. GME TX3100 UHF. Scanguage II. Drifta Drawers. Wetseat Covers. Toyota. Dual Battery System. MSA Seat Organiser and Table. MSA Wheel Bin. Staun Deflators. Toyota Tow Bar. Ironman Underbody Protection Plates. Waeco CF50. Performance Chip. TJM Airtec Snorkel. Sandgrabba Mats.
Come to a stop then give it a good shove. Don't worry too much if it's only a slight crunch.
Jim.[SIZE=1]Cheers Jim.
[/SIZE][COLOR=#0000cd]
There is no synchromesh on the transfer case gears so some noise is likely. Slight crunching noise maybe ok. Try engaging low range from a complete stop (as suggested) a few times and see if it always happens. You could try putting the gearbox in neutral to take any drive loads off rather than rely on the clutch (manual) or the the torque converter.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
In my previous 03 120 I could shift into LR from neutral or park with no noise at all. In my current 09 120 I can only shift into LR with no noise if I'm in Park with my foot on the brake. It can not be done from neutral without some serious grinding noises. I can get away with it sometimes if the vehicle is dead cold, but once it's hot ... no chance. I thought it was only an issue with the 120's.
Bazza.Last edited by Bazza; 11-06-2011, 08:52 PM.[i]I'd rather laugh with the sinners than cry with the saints![/i]
Thanks guys. I always engage low range when fully stopped and the 150 won't engage low range unless the auto is in neutral. It's only a very slight noise that is probably fine. In for the 20,000km service this week so will raise it with the service guys.
Cheers, Sam.150 GXL V6 Auto. BFG AT 275/65/R17, ARB Deluxe Winch Bar, OME 2" Lift, Firestone Airbags, Dual Batteries, GME UHF, Rhino Sportz Crossrails and Platform Rack, ARB Awning, Redarc Brake Controller, Rear Drawer System, Safari Snorkel, New Toyota Mudflaps, Kaymar 'Wheel on Door' Bracket, ARB Under Vehicle Protection, IPF 900XS Spotties, Allied Hammer Wheels. Disclaimer - I am an ARB employee. [B][URL="http://www.pradopoint.com/showthread.php?17348-Sam-s-150-V6"]Buildup Thread[/URL][/B]
