Reading 150 series ECU
  • Reading 150 series ECU
    I would like to be able to read info from the GXL's ECU. I know pretty much nothing about this but suspect that Toyota use OBD-II?
    If this is correct, has anyone looked at IOS apps that can read this data? One that I have found is DashCommand which is also available for Android:
    http://itunes.apple.com/app/dashcomm...321293183?mt=8
    The same company sells hardware to interface with the software at:
    http://www.palmerperformance.com/hardware/index.php
    Has anyone used this software or hardware?
    Is this the correct hardware for the Prado?
    Thanks........
    Don't know about the above but you can use a scangauge or Dashdyno Pro. Lots of info on scangauge on this site. For info on Dashdyno pro refer following link:
    http://www.auterraweb.com/
      Thanks for that. Will have a look at both.
        How did you go with this? be interested myself.
        I used to be apathetic, now I just dont care !
          Haven't had much of a chance to get very far over the last week. Hopefully next month will have some time and will let you know...........
            I have asked the same question somewhere else, but has any one figured out if you can get engine oil temp on a scangauge running v4.02?
            2010,Prado 150 D4D GXL manual, ARB deluxe bar, iron man 9500 winch, IPF 900XS converted HID, pirrana duel battery tray and controller, 50mm lift toughdog springs and shocks, GME TX3440 uhf, false floor and ORS fridge slide 60ltr Waeco fridge, kaymar rear bar, with anderson plug, safari snorkel, Mickey Thompson 265/70R/17.
