Tyre Pressure
  • Tyre Pressure
    Googled this to death and its bound to be here somewhere but still cant find the right tyre pressure for 265x70x17's, I know with the 16's it was 40 front and 38 back is it more for a 17 ?
    cheers and a happy new year to all.............
    Atheism is a non-prophet organization.
    Davy,
    Its a bit of a personal preference, but I use 40 front and back. 35 on gravel 25 on the trails and 15 on sand. There is a thread on this somewhere.
    Greg
    Greg - 08 D4D Prado,
      Have a look at this thread....
      http://www.pradopoint.com/showthread...ssure-Database
        4 PSI rule?
          Post #7 of this thread gives an idea of the 4psi rule
          http://www.pradopoint.com/showthread...ssure-question
            Yep, that's what I use.. you cant just use what someone else is using as they may have different mods or drive on different terrain, both factors result in a variation of "optimal" tyre pressures.
              I have my tyres on about forty psi but i went up the bush the other day and let them down to thirty psi and it was great nice and smooth should have done this years ago.
                Thanks for the input guys, I think 40 should be right just thought it might've been more with a bigger tyre but all good
                cheers,
                Davy
                  Depends on the tyres. The standard Dunlop Grandtreks is recommended as 29psi allround if you look at the manual. On my previous set of BFG i would run at about 40 psi.
                    I love how the manual recommends 29, which is a bit low.. But when toyota puts air in your tyres (even when you ask them not too) at a service they put 50psi in.
                    2011 150series GXL
                      For me loaded with 4 passengers
                      40 psi - general use
                      45 psi - towing van
                      25 psi - high country/mud & rocks
                      Steve.
                      Stephen Bloomer
                        There a whole thread (database) on tyre pressures. Perhaps if this thread was a little more specific in its title.
                        [B][SIZE=4]ntp
                          It is very hard to get anyone to commit to a tyre pressure guide, they must be scared of being sued. I use much the same as those above or a little softer. 34 - 36 general use, 38 - 40 with the van and 25 all around on the dirt down to 20 in steeper or muddy country and 14 to 18 in sand. If the tyres are too hard you will risk tyre damage and wear the centers out, before that you will say the suspension setup you have is crap. If the tyres are too soft generally you will wear them out faster some say that you will use more fuel as well. You will get a better ride and better grip as the payoff. If you are on a trip and get onto a gravel road with some corrigations and are getting slower and slower and getting pissed off, pull over let the tyres down to 25 all around. When you set off again you will not believe you are in the same vehicle. That is the difference tyre pressures make.
                          Prado Polar White 150 GX 3.0 TD Auto. HR TB, ARB delux bar, Hella R2000 lights, Magnum winch, ARB 50mm lift, BFG AT 265/70R17 on 71/2" alloys, Alloy side steps, Rhino sport bars, Tint, UHF, Scangauge, Aux batt (ABR kit), Cargo barrier, 50l water tank, Storage system, Elec brake con. ARB compressor
                            Im similar to you barajack.
                            36 normal use, i dont change it for towing my Jayco camper.
                            25 on dirt.
                            20 on rock/shale/mud.
                            15 on sand.
                            [size=1]2011 GXL D4D Auto | ARB Deluxe winch bar | Bilstein/Ridepro platinum lift | MT ATZ P3's | Dick Cepek Torque rims | Airtec snorkel | Lightforce Genesis 55w HID | GME UHF | 55w HID high beam | Rhino Rack bars & Cage | ISI extreme rack | Dual Optima Batteries | Milford MXV-70 cargo barrier | ARB onboard air | Prodigy P3 | Drawers & Black widow fridge slide | Waeco CF-50 | Kaymar rear bracket and LED light | EscapeGear seat covers | Sandgrabbas and more...[/size]
                              For me
                              36 psi - general use
                              38/40 psi - towing van
                              25 psi - Dirt/rocks
                              20 psi sand (drop lower if needed)
