noise when engaging low range
  • noise when engaging low range
    does or has anyone else noticed a grinding noise when engaging and dis engaging low range
    [url=http://postimage.org/image/1vynucrno/][img]http://s3.postimage.org/1vynucrno/2011_prado_side.jpg[/img][/url]
    Mine just clunks a lot.
    *edit* it probably grinds as well now I think of it.
    2011 150series GXL
      Yep mine grinds but not all the time though!
        Are you trying to engage whilst still moving, the gears are cross cut and do not have synchros like a normal gearbox so will grind when trying to mesh.
        Best to be not moving when engaging although can disengage quite easily (even in an auto) whilst still moving
        Kev,
          I have accidently made mine grind once selected drive before the dash light had stopped blinking. ( L4 to H4 ).
          Makes the type of noise that reminds you not to be impatient next time.
            kev7762 no not moving as my prado is a auto and i can only get it into l4 when in netural
              You can get into L4 on the move. As you're rolling (slowly) put it into neutral and flick the switch. It'll click over when it's ready.
              If you're going to fast it just won't click over into L4.
              But yeah... Make you're you're driving slowly if you do want to do it.
              2011 150series GXL
