As i have mounted the iPad on the dash I need to charge it, plugged the apple cable into the factory USB and it won't, it will charge my phone though but not te pad, have to use a cigarette lighter type charger to charge the iPad, any thoughts as to why no charging with the factory USB??!
Apple geeks, help with factory USB
not rated for the mil amps needed
You can get one of these http://www.baintech.com.au/baintech/baintech-single-usb-socket-surface-mount
there is also a double USB which would be better in my opinion. When powering the iPad you only use one of the two USB ports_______________________________________
[SIZE=1][B]2011 Silver 150 DVD[/B] [B]GXL[/B][/SIZE][SIZE=1], Safari Snorkel, Sand Grabba mats, Michelle Sacs seat organizer, ARB Bull Bar, Lightforce 170 HID, Bonnet and Headlight protectors, Dual Batteries, Engel Fridge, Kaymar rear spacer, Cooper STTs [B]x 6[/B], Rhino Pioneer tray in black, MaxTrax, Black Widow Drawers with top shelf, divider & cargo barrier, ARB Sports Nitrochargers and springs, ICOM IC 440N CB
[/SIZE]
Yep same problem here, you need a specific iPad cigarette charger 10 watts, most places sell them I purchased this one http://store.apple.com/us/product/H2...de=MTc0MjU4NjA and it works well, nice low profile.PradoPoint GTG 2014 - Iconic High Country - Victoria
Big Thanks to Our Sponsors
#ARB 4x4 Accessories, Dobinsons Spring & Suspension, BCF, Terrain Tamer, ORU, MAXTRAX, REDARC, Kaymar, Opposite Lock, Hema Maps, BushSkinz, Piranha, High Country 4x4 & Century Batteries
Originally posted by smakb View PostApple put in a block to stop iPads from charging from computers. I use a cigarette lighter to USB adapter and that works.
Steve
Rob grab a Baintech power port as above or you can get a 12v socket adapter as well for it.-----------------------
Daniel
Unfortunately I had something in the cig plug already so was hoping to use the USB, looks like I will have to put the double adaptor back in.[b]Rob[/b]
Originally posted by Hutch View PostUnfortunately I had something in the cig plug already so was hoping to use the USB, looks like I will have to put the double adaptor back in.[SIZE=2]Black 2009 150 Series D4D GXL Prado, [B]TG150[/B] Transfer Case & Actuator Guard, TJM T13 bar, TJM 9.5lb Winch, Airtec Snorkel, TJM steel sidesteps and sidebars, TJM Underbody Protection, TJM XGS Gold Suspension, Tinted, ARB Fridge Freezer, Couplertec System, Foxwing Awning, 80AH Dual battery, 8" indash GPS, Wet Seat seatcovers, GME TX3540, TX3110 & TX680, [B][COLOR=#ff6633]Maxtrax[/COLOR][/B], Kaymar Dual Wheel Carrier, Breathers, Federal MT's.[/SIZE]
We have run an extension cord from the 240 volt inverter in the back of the car under the rear draws, it comes out in front of the back seat in the middle on the floor and has 2 out let's on the end of it. We just plug our I phone / I pad / I pod / I pod touch / i what ever charger in or 2 and keep every thing charged on the go
When stopped we us a can verter in the car or camper .
