Ticking Noise
  • Ticking Noise
    Well I thought someone may have been playing a practical joke on me when I ensured that there were no rocks caught in the tread of my new Coopers, I crawled underneath the prado looking for a zip tie around the tail shafts, or CV shafts however no zip ties can be found. Hopefully the above explains the noise i'm hearing when driving along. The noise is not there at idle or when reving in neutral (whilst stationary). Any clues it's driving me bananas - appropriate metaphor considering I'm holidaying in Coffs Harbour.
    [SIZE=1][B][COLOR=#ff0000]2010 Silver GXL Prado T/D Auto.
    [/COLOR][COLOR=#0000ff]2014 Leisure Matters X-Track Camper Trailer.[/COLOR][/B][/SIZE]
    Does the ticking get faster when you accelerate? Where does it sound like it's coming from (front/back/left/right)?
    Mike
      Mike
      Hi Mike,
      Its coming from the drivers side more so the front (I think) I'm noticing it above 40 Klm/hr.
        Well I was going to say rock in the tread... but anyway, do you have weather guards? I had a ticking/tapping sound which only occured at speed... it turned out that the double sided tape came off on the front end of the drivers side weather guard causing the guard to tap against the door as the wind hit it. Got some outdoor double tape and no more tapping sounds...
          Here is something my wife parks the Prado under a tree at work and there is always leaves getting into the grill area at the base of the windscreen, you only notice the sound as the speed picks up.
          Richo.
            I have a similar sound from the right front. I believe its the plastic inner guard as the screw holding it in place against the ARB BB bash plate is MIA.
            Just a thought.
            Hazza
              William, Richo & Hazza thanks for the ideas will check at first light and report back.
                Fabes, this may sound a bit strange but it helped solve a long term annoying ticking noise coming from the front of my car. Try wetting the windscreen and see if the noise goes away. If it does it will be the felt/plastic seal rubbing against the windscreen, took ages to track this down.
                [B]Steve[/B]
                  Thanks for your suggestions guys, ithink I found what it is. When they have fitted my new tyres they haven't clamped up the weight on the inside of the rim correctly as its a bit loose and makes the sound I'm hearing (I think) off to the tyre shop today - after visiting pebbly beach north of coffs
                    With all your testing of those new shoes Shane, it could have been the tracks that made the wheel weight come loose?
                    Don't worry, the rest of us will just keep going to work and being jealous of your fun.....
