Blackvue dr500gw-hd wifi Dashcam
This topic is closed.
  • #91
    Yeah mate removed the grab handle, removed the door rubber, side trim, scuff plate, kick panel, then just ran the wire behind all this, (I wacked in a couple of cable ties just to stop it flopping about) then I removed the panel from just above brake pedal and ran the wire across to the edge of center console, plugged it into power supply then what cable was left I wound it up and cable tied it out of the way.. [IMG][/IMG] [IMG][/IMG] [IMG]
    Steve M
    Addicted PP Member
    • #92
      [IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
      • #93
        • #94
          Should also say where it comes up from behind my mirror I just tucked it into the hood lining and when I pulled the side trim off near grab handle I made sure the cable had pulled back over the hood lining a bit more so it wouldn't drop down in front of windscreen. Took me about 1 hour all up would be quicker next time as I know where the clips and things are. I took my time as to not break any clip or trim......hope this helps you out... Cheers Steve
          • #95
            Legend! Thanks. I get scared removing trim, in case I break a clip, this helps immensely. Having a poke around this afternoon, it looks like there is gap at front of the hood lining tailor made for the cable! Not sure if its original or from the previous owner, but it will do nicely!
            • #96
              Originally posted by stevejau
              Also, it would seem some gave the coupon codes to others, which is cool, and as a result you guys bought 19 Blackvues and 2 Vico's.
              opps busted. I gave it to a couples of friends earlier when there was only a few here made the payment, just to make sure your hard efforts won't blow off.
              looks like they bought some as well.
              • #97
                Thanks Steve, something to do when i get back from the mine site this arvo, footage from some tracks from up here will be on PP in the near future.
                Cheers Derek
                • #98
                  Thanks for the update Steve, was going to ring them myself and find out where it was, but i'll give it another day.
                  cheers
                  Adrian
                  Silver 2012 150 series D4D Altitude Prado, TJM T13 Bar, Airtec Snorkel, Koni HT Raids suspension, TG150 Transfer case guard, Dual Battery, LightForce Genesis 210 35w HID, Rhino Rack Pioneer Platform, Foxwing awning, MaxTrax, TraxRax, Cooper's AT3, GME TX 3540, Sand Grabber mats, Hema HN6, Drifta Draws, ABR - Sidewinder Kit, MSA Fridge Drop Slide, Engel 40L, Brown David underbody plates.
                  • #99
                    Not a problem Adrian..I will not be happy until i know each of you have received your cams, rest assured I have been in contact with them daily.
                    Steve
                    Mine arrived this morning. Haven't played with it yet. You and your possums can sleep a little bit easier tonight. Thanks again for organising this!
                    (Had a Heart attack when I saw the manual is Korean, until I read the note telling me it's on the SD card ! )
                    • Hi Steve
                      I may not know until Monday as away Friday
                      Charlie
                      Charlie
                      • Don't panic r4ndll, once you have used it once or twice it's simple as to operate. Plenty if little bits to play with. Best way to set up correct position on screen is using the live view. After a while you will forget its even there unless its in your view. At first you may stop singing to yourself out loud but then it won't bother you lol...... Cheers Steve
                        • Arrived this morning, a little bigger than i thought, but will hide perfectly behind rearview mirror.
                          Thanks guys for making the group buy.
                          • Originally posted by Steve M View Post
                            Yup, think I've got it now. Im not at work today so its in position on the windscreen, and have already been for a little test drive. Will tidy up the wires this weekend as they're just running down the pillar. Played with the software too, i like the little map function.
                            I thought the same, but it fits well behind the mirror. The previous owner fitted an e-tag above the mirror so it's the only place that it fits, but can't see it from the drivers seat at all. The silver lens surround stands out a bit so I might take to it with a texta
                            • I just ordered one with the code you sent me last night - thanks again Steve.
                              • Hey Steve
                                I got mine late yesterday afternoon.. Only tested it at my desk but the quality seems really good!
                                Thanks again
                                [SIZE=2]SBIDDER
                                2013 Prado GXL Auto - Glacier Wh[/SIZE]ite
