  • Received my springs and shocks from Zordo. Off to buy a trolley jack now so I can have a crack at installing it myself.
    Where's a good spot under the front end to jack from ?
    • Front jack point under the front doors on the chassis.
      While you are at it, get some decent jackstands.
      • LOL yeah I know I can use the jack point on each side, but I meant in the center for using the trolley jack to raise the whole front end at once. Or can't this be done ?
        I already have chassis stands.
        • There is a circle pressing under the engine, That is the jacking point.
          4WD SUSPENSION & BODYLIFTS 0418780611 A/H PH/FAX 07 33512692- [COLOR=#ff0000][SIZE=5]Bilstein, Ironman & Roadsafe Distributor [/SIZE][/COLOR]
          • You'd need a central jack point, not sure if there is one... (there is, thanks ZORDO)
            Only takes a couple of minutes with a trolley jack.
            • If I have aftermarket bash plates will that central jack point be accessible ?
              • Note the position of the mounting bolts to the crossmember & use a bit of 2 x3 on the floor jack so it does not damage the bash plates
                • Paid off wedding ... so I ordered a runva 11xp premium over the weekend
                  Am depositing the $ for tins uvp tomorrow morning
                  Then I just want a spot gen3 before doing a cooma to the coast trip with the wife, dogs and hopefully some diy drawers :-)
                  • Finished installing a Uniden 8080S UHF. Power via the middle console cig lighter wires - pretty easy to get to when you have everything apart, as the entire middle console just lifts straight up and is all clips. The mic/speaker/control plugs into a modified switch blank with the extension cable running back to the UHF. Easy enough to run the antenna cable through the firewall on the passenger side. The head unit is mounted in the 'business card holder' area. The mic is held in place with a ClicOn.
                    • Have started the long process of choosing some new rubber.
                      Too many options...
                      Will be looking to up the size to 265/70s
                      Spilsy
                      • Bit the bullet and ordered some 9inch Illuminator lights. $199 with 10 copies of 4WD action Magazine and free postage.
                        Spilsy
                        • Originally posted by Spilsy View Post
                          Will be keen to here your opinion on them spilsy was deciding between these and some Frylyght spotties.
                          cheers
                          • Originally posted by Rdae1981 View Post
                            cheers
                            I'm keen to find out too. From what I have seen on here and the FJ cruiser forum, they aren't too bad. Decent light and a solid mount.
                            http://www.fjcc.com.au/f34/4wd-supa-...39/index2.html
                            The current draw is apparently quite high, so I may need to upgrade the wiring.
                            Spilsy
                            Spilsy
                            • Got it back from 90k service.... And the radio replaced under warranty.
                              Needs transfer case and both diff oils to be flushed still!! Will do myself hopefully!
                              -Safari snorkel
                              • TNF 52/12 ECU flash done, CV boot replaced and service carried out. Runs like a dream now!
