Cargo Length with Rear Seats Down
  • Cargo Length with Rear Seats Down
    I would like to fit some gear into my potential new 150 but I am not sure if it will fit. I have searched on the internet and cannot find the dimensions.
    Could anyone please kindly check the distance from the tailgate to the back of the front seats with the rear seats folded
    I guess there might be two measurements:
    a) flat along the floor to the back of the folded rear seats, or
    b) angled from the floor at the back and resting on top of the folded rear seats.
    I am hoping some gear that is about 2.3m long will fit into the 150 without needing to slide it between the front seats.
    Thank you
    You will need to slide it between the seats. I haven't measured mine inside but my 7' (2.1m) fishing rods don't fit.
    For reference the awning in the picture is 2.5m
    Sent from my GT-I9305T using Tapatalk
      I fitted a 2400mm flat pack table in the other day(about 600mm wide , and 100mm high). Was pressed up against back door, and sitting on dash mat. Front seat all the way forward, layed back, and middle row seats down. Was a squeeze, but got it in. Couldnt see passenger mirror in trafffic was the only driving problem i had. I can fit 1800mm shelf unit in with passenger seat about half way forward(lucky i have a short wife :-) ) Hope this helps. Trev
        You can just fit a 6 foot ladder inside, 1830.. No way 2.3 is going to go.
