How do I remove the overhead console, it's the console that has the map lights and the sunglasses holder in it? Thanks in advace!!!
How to remove overhead console from GX Prado?
Gday MIGALOO_GX
Originally posted by MIGALOO_GX View PostHow do I remove the overhead console
Should just pull out but logic caution to be taken to not damage roof lining or housing.
Clip part numbers:
2 x of 90467-10161 (front) $1 USD each
2 x of 90467-10167 (Rear) $1 USD eachLast edited by SWR; 07-02-2015, 10:16 AM.
Originally posted by SWR View PostGday MIGALOO_GX
It is held in by 4 x panel clips similar to the type that hold a door panel on. (2 x @ front part of the sunglasses holder & other 2 x @ back part of the sunglass holder.
Clip part numbers:
Originally posted by MIGALOO_GX View PostI'm having trouble figuring out which cable is power so I can run my rear view vision reverse camera (wireless)
The simplest way out (If not savvy with a multimeter) is to get a test light & put the crock clip end to a good earth then poke around (All doors closed) and test each wire for a power supply.
An ignition live would be the smarter choice! (Will switch off when ignition off).
TIP! .. Rather than forcing a test light or multimeter prong into socket plug (Is small needle tips) use a sewing needle to penetrate the wire then put test light onto the needle.
Here is some >>> test-lights<<< for an idea on prices if you don't own one but a local car accessory shop is your quickest option!
Originally posted by SWR View PostI can't help you on that one as i own a 120 series & not 150 series so don't have a wiring diagram!!!
Originally posted by MIGALOO_GX View PostHow do I remove the overhead console, it's the console that has the map lights and the sunglasses holder in it? Thanks in advace!!!
Originally posted by ash56 View PostWhat year model is your gx? Mine is an 2012 and its got a useless convex mirror instead of the sunglass holder, I would much rather the sunnies holder. Sorry if ive gone off subject.
Not sure if yours is the same though.
It fits my prescription sunnies or glasses really well, but doesn't fit the wifes sunnies, so no arguments over who gets to use that hole.[LEFT]Silver 150 Facelift
Originally posted by maulbeagle View PostHave you tried pulling down on the mirror part ? My 2014 150GXL has the convex (conversation) mirror, but if you pull down on it it also has the storage compartment above it.
Eventually I realised the centre dash vents were pointing up...[I]A good friend will bail you out of gaol, a true friend will be sitting beside you saying, "wasn't that a blast"[/I] ...
White (sorry Glacier White) 2013, 150 D4D GX + the bits that will no longer fit in this space.
