Hi all,
Arrived back from a 9000km trip out in the centre in Sep, and there's still red dirt coming out of the rear door.
Every time I wash, I get red trails down the back window which gives me the $h!ts.
So I decided today to take a few rear panels off.
The rear bumper cover was fairly easy.
So I hosed that off.
I wanted to remove the rear spoiler/brake light assembly to hose it out, but as I was loosening the screw (from the inside, top-left of rear door), it fell back into the door cavity.
So I proceeded to remove the trim and look into the bottom of the rear door. I was amazed at the dust which had congealed.
(found the bolt!!!)
I managed to loosen it a bit and shove a vacuum cleaner in there to pick it up.
...but I'm sure there's a tonne more left.
Two Questions:
1: do I need to worry about the dirt still inside the rear door? I could shove a hose in there and let it drain out the 3 drain holes:
Or do I just let it be, given it looks relatively dry.
2. I removed 4 x 10mm bolts which appear to hold the rear spoiler/brake light on, but it still won't budge. Any tips on getting it off?
(found the bolt!!!)
Two Questions:
Whitey
