Anyone know where we can get an upgraded spare tire lock to better protect against theft ?
Spare tire lock
If it is the same arrangement as a 120, I purchased a railer hitch pin lock,
then got a freind to turn it on his lathe to the same shape as the bolt on the tyre mount
that the original lock uses.HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
Use to be able to remove the Prado spare wheel lock cover with the Camry wagon key...Originally posted by Nova View PostDidn't know the standard one was bad??
Cheers, Nova
My spare gets the same mounting torque as all the other wheel nuts 83 ft./lbs.
Don't know if the ice heads trying to knock your spare off could handle the strain, but it will not make it easy for them..SOUTH AUSTRALIA GATEWAY TO THE OUTBACK!
Again, If it is the same as the 120, one key fits all!HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
You don't reveal your location.Originally posted by Pradoristi View PostAnyone know where we can get an upgraded spare tire lock to better protect against theft ?
Obviously live in a higher crime rate location than most because theft of spare wheels from the rear of cars is virtually un-heard of.Last edited by Bushbasher; 03-10-2016, 05:44 PM.Dave
