3 tonne towing capacity upgrade
    Originally posted by Brodad View Post
    How much does it cost?
    what model prado do you have 120 or 150? are you in NSW?
      150 and car is registered in NSW
        we have done testing on both factory and hayman and reese tow bars so that is not an issue for the 150 series. the 120 series prados we fit a hayman and reese tow bar as part of the kit.
        Perhaps an update to the promotional material to include hayman reece would be beneficial?
          we will consider it. we don't want to confuse people by overloading them with info. we are happy to assist any customers with specific questions about the product if needed
            Hey,
            Which Bilstein part numbers are being used for the upgrade?
            Best
            Mark
              Hi, I will be soon needing a towing upgrade on my 150 gxl, could anyone let me know if this can be done in Victoria or do I need to travel to NSW. Cheers
                Just did a quick search for you on google check out statewide 4x4 the are in victoria and are offering gvm upgrade give them a call and see if that will suit or if you need a GCM upgrade.
                  Ollii, are the upgrades limited to GX/GXL or can you do the VX as well? Are we talking about the 150 Series with 2.8l engine?
                    I have just spoken to Ken from Ultimate Suspension in Ingleburn, and he said that the GXL Prado has just been approved for a 4 Tonne Tow Capacity upgrade.
                    Now coming from having 2 LC200's with their GVM upgrades, I made him repeat himself twice to make sure he was talking about the Prado, not the 200 Series.
                    He confirmed that it was the Prado, and not just the LC200. There are also GCM upgrades as well.
                    Now I dont intend towing with my Prado, or indeed towing 4T with a Prado, but nonetheless that is what he told me. Give them a call if you like.
                    BTW I have no affiliation with them what so ever.
                      I have just had this done to my 3L 150 GXL through Active 4X4 at Beresfield. I included a 2 inch lift also.
                      I had not towed with a vehicle equipped with air bags before and had only used the HR system, the air bags are easier to use and less hassle. All appears great so far I just have to find a suitable pressure to set the Airbags at.
                        Hi Chong if you dont mind me asking how much was the whole set up from Active 4X4?
                          4 tonnes? No way sorry..
                          • #28
                            I had other work done as well but I believe it was around the $3k mark.
                            That included 2 inch lift and adjustable front shocks.And the Air bags also.
                            $450 for the Engineers Inspection and nothing at the RMS to update Rego Papers and 30 min on the phone to Coles insurance explaining why I lifted the car.
                            • #29
                              Does anyone in SA do this or had it done
                              • #30
                                The gross vehicle weight combination upgrade I can understand.
                                But I did not think you could upgrade the gross vehicle mass at all, with out major engine brakes axles etc plus engineering reports.
                                I had my Hilux GCM upgraded before first rego, not a problem, but I could not get a higher GVM update.
                                Charlie
