2nd row of seats 150 GXL
  • 2nd row of seats 150 GXL
    Does anyone know how to remove the 2nd row of seats, do they come out easily and are they easy to put back. if so do you have step by step instructions. thanks Dan
    4 bolts along the front, and I think 4 bolts at the back. You will need to slide the seats forward so the back bolts are easier to access. Comes out in 2 seats as drivers side + centre, and the passenger side.
      Make sure you unplug the connector on the passenger side seat!! I can't remember if there is one on the drivers side.
        Google the instructions for MSA seat covers as you need to remove the seats to fit them.
        The covers came with step by step instructions but they're pretty straight forward.
        They also weight a ton!
          Something to consider: If you plan to drive with them out, it's illegal...I've had two cops tell me this, but didn't have a problem with it, as I clearly used it for storage and didn't have people sitting there. But they did warn me.
          Apparantly you have to remove seatbelts if you remove seats, and if you remove seatbelts you need to get it re-classified or whatever as a 2 seater, which means you can't put the seats back in and use them.
          I wonder if that applies to the rear seats as well, as 'everyone' takes them out. Maybe they are different as they are designed as a removable item.
          Or maybe the two cops were just looking for a reason to have a go at me.
            You've probably already got all the info you need but yes, easy to remove. I haven't tried putting the seats back but should also be easy, perhaps take photos as you remove the seats so you can later remember how to reinstall.
