2018 Prado gxl side step lights
  • 2018 Prado gxl side step lights
    Wanting to fit lights under side steps, any advice on what to use and how to connect to lighting so come on when approaching vehicle or unlocking, thanks.
    Have a look underneath the sills around the area beneath the centre door pillar. There's a wire coming down from underneath the front seats & ending in a blank plug on a bracket under the sill. I've been told this is for under sill lights in the Kakadu. Whether this is correct or not I don't know as I've never checked it out but could worth putting a multi meter on the plug & see when you get any readings.
    Give it a go & let us know what you find out.
    [COLOR=#b22222]Prado 150 2.8 GX Auto - ARB Bull Bar, Towbar, Dual Batteries, UHF, 2" lift with King Springs & Bilsteins[/COLOR]
      Thanks will try
        i changed the t10 Halogen globes from my 2013 VX to a LED bulb. the lights come stock on the VX the LED made a world of difference. I bought the lights from Stedi Australia.
          Nice any chance of a pic of the led bulbs?
          2018 VX Prado
            wire under steps is for lighting but its dead ie not active
              Did anyone check to see if fuse was in before checking the wire?
                https://www.stedi.com.au/2-pack-t10-w5w-wedge-led-light-28mm.html
                  I spent a couple of hours on the side step wiring on my GXL over the weekend. I pulled all the wiring diagrams and plug layouts for the LH Footwell. I traced just about every plug that references the Side Step and I was unable to locate a loop down to the plug under the sill. One of the pins is Earthed. That surprised me as when I activated the Red Ambient Lights on the map light unit all I had to do was earth one pin to get them working. I assumed the side step lights would be the same - no such joy.
                  There must be something somewhere that activates the circuit, I just have not found it. I also couldn't locate a pin on any the the plugs that powered up with the Door Courtesy or Internal Lights. I initially thought if I could locate that circuit activation I could just use that to switch a relay for some step lights. No joy.
                  I like the idea of piggybacking the internal lighting circuit so the step lights come on when you walk up to the vehicle with the key in your pocket. I guess some day when I have more time I might try it again.
                    Has anybody had any luck with this?
                      Someone managed to connect the lights, I already have them installed downstairs but I don't have power, do you know what to do?
                        Likely they may need either a fuse/ relay or both added, or more likely ECU programming to activate.
                          Yesterday I was watching the programming with the techstream, really in courtesy lights you have to activate the footboard lighting light, But even so, there is no power downstream
                          pendik escort
                          sisli escort mecidiyekoy escort
                          sex vidio
                          ankara escort
