Mounting a Piranha DBE 180-SX Dual Battery Management System in a 2018 Prado
  • Mounting a Piranha DBE 180-SX Dual Battery Management System in a 2018 Prado
    Hi,
    I am wondering if someone could share where they have mounted this specific unit in their engine bays please. I was looking to fabricate a plate which would bolt into existing thread but hope someone else can share their thoughts please.
    Regards,
    04 VX Prado Diesel, Sovereign Bullbar, Safari Snorkel, Piranah Dual Battery Management System, TX 3400UHF, Cargo Barrier, Lighforce Driving Lights, Windcheater Roof Rack, Outback Recovery Points, 2" lift Bilstein King Combo, Firestone Airbags, Engel & Black Widow Slide, 48lt Boab Water Tank.
    That unit is not suitable for your model.
      Thanks Leigh, I have spoken directly with Piranha and they have said that it will be fine when charging a deep cycle battery however it will not suit Lythium and I think AGM batteries.
        Piranha have a specific bracket to suit their unit to fit the Prado. ( well they did for my 2015 model 3.0 litre back in 2015) went behind air filter on the sidewall
          Piranha are wrong !
            How wrong can they get it, a deep cycle battery is an AGM battery! About the only battery that system will
            work with in your model is a Lithium one.
            Piranha are leading you astray, your Prado is fitted with a low voltage alternator and your battery
            will not charge your battery using their isolator. Normally they would also sell you their very expensive
            AOC to raise the voltage to a suitable level but you can't use a booster on your model.
            They have sold you a product that won't work effectively with your model, take it back for a refund.
              Just to note I removed from my old 120 so all good.
                ok not bad then, pity it can't be used in your new setup.
                  solenoid isolaters are going the way of the dinosaurs , they ant so cheap when you cant take them out of your old rig and drop them into your new one
