Front left squeak
  • Front left squeak
    Hey guys. I have a small but persistent squeak that I’m trying to identify the source of.
    theres a squeak somewhere in the front left of the car that only begins after longish drivers (1 hr or so) and while the car is moving (suspension/brakes don’t seem to be related)
    any ideas or similar experiences?
    2012 Prado GX. 2" Pedders lift with Nitto Grappler tires. Power Chip and Throttle Control, 3" exhaust, Safari Snorkel. BCDC Dual Battery Package. Next Install: Head Unit
    I've got a similar thing sometimes, also from the front left on my 2018 Prado GX. Although, I would describe it as a continuous squeal. Braking or accelerating usually stops the squeal. I figured that it is a small stone or dirt in the brakes (between the rotor and dust shield?). It usually goes away after a while. I've tried reversing to try and dislodge the stones/dirt, and I think that has worked. I guess taking off the wheel and inspecting/cleaning could help too.
      Could it be the seal in the exhaust join around that area? There are discussions on this in other threads.
        I also have the same problem but however have gone away
        is it more at low rpm if so open the left window and why you can hear the put the car from D to N and see you still have the noise my stop after four months just before toyota replace the engine
          I had my head under there the other day and didn't notice anything - but not exactly sure what im looking for. It's definitely possible though, only present (or more prevalent) at low revs and once the engine warms up, doesn't seem to be braking/suspension related. The only thing that doesn't support this would be the left hand side origin? The exhaust runs under the drivers seat.
            The other factor that goes against the exhaust is I have an aftermarket redback exhaust fitted.
            kartal escort
            sex vidio
