Hi, I am determined to fit a LiFePO4 lithium battery as a accessories power supply and basic dual battery system in a 150 2015 3L Prado GXL. The air con piping seems to interfere with the area designated on the driver side of the engine compartment. The battery is 306mm long and simply does not fit. Has anyone had this problem and was able to fix it, work around it or come up with great solution. Even thought of putting it in the back somewhere but nothing stands out as a well disguised place or that doesn't restrict loading the back with gear. Any ideas would be welcome.
Prado 150 2015 limited space for aux battery
I too have been looking but most I have seen are 330 mm long. In the 2.8 motor the 300 ish mm ones fit fine as the AC pipes are in a different place to the old motor but the 330 are within a mm or 2 of various pipes. My current old deep cycle is about 300 and fits fine on the TJM tray I have and am not about to change. If I could get a lithium at that length I may go that way as there would be cooling space to the pipes.
Looking at the X-CELL specs for operating temperature a Charging Temp range of 0 -40 degrees is definitely not suitable for under bonnet use imo.
Unless the battery warranty specifically states warranted for under bonnet use I would not fit one there.
I have a Enerdrive 100Ah slimline battery behind the second row seats with a Enerdrive DCDC charger mounted on the cargo barrier which works well.
Lee'18 VX, Billies with Dobinson springs, Summit bar with Narva Enhanced Optics to help my old eyes
Originally posted by Daniel150 View PostI may be wrong, but I was under the impression that lithiums are not recommended under the bonnet as the ambient heat will kill it prematurely.
specs say...
The VoltX 12V 100Ah lithium battery is composed of brand-new A-grade prismatic cells, making them super reliable and energy-dense.
Its super-effective integrated battery management system (BMS) keeps the battery to safe operating limits – disconnecting it to prevent damage from temperatures/voltage changes, overload and short-circuits
These are not Lithium Ion batteries which have a real problem, they are LIFePO4 with proper BMS chips built into them to protect them.
Time will tell.
DeeBee: how about a battery box in the rear that you can take out when camping? and connect to the alternator when driving? if you don't want to take the risk/expense of moving the aircon pipe.Steve
2007 Prado 120 D4D 6 spd, 25/40cm lift ARB OME, snorkel, Brown Davis sump guard, Pirelli ATRs (Road), Cooper ST maxx (off Road), ARB lockers & compressor, Overkill rock sliders, dual D27F Optima Yelowtops, Ctek D250, 130A alternator, breathers, GME TX3440, Yaesu FT-857D, Buscomm Highlander 8 multitap or ATAS antenna, ARB Fridge. (VK2FSVN)
Originally posted by krypto View PostWhen I've looked at the battery specifications, the temp range is usually below the temps seen in an engine bay. Possibly no short term harm, but perhaps an effect on longevity.
Another option if you definitely want lithium under the bonnet is to go smaller.
100ah of wet cell is about the same as 60ah of lithium due to the depth of discharge available in a lithium. This means you could go smaller, potentially.
I’d also look at the charging as well. Lithium really needs a lithium charger, they don’t charge well off an alternator alone.Last edited by Daniel150; 27-03-2023, 05:02 PM.
Thanks for the input from everyone. I like the idea of a smaller battery given my intended usage (fairly basic). The dcs 75ah looks good.... a bit expensive but has great specs and a bms internal. I also like the idea of a removeable unit in the back. Happy to hear more ideas and input. Thanks
