New Key Needed... $400
  • New Key Needed... $400
    mmm my child minder lost the key!! $400 to replace (and $1,000 if you lose the second one and have to recode the whole system).
    Any idea whether you can buy the fob elsewhere and have it recoded (like off the net etc)... I can't risk taking the only key we have surfing now!!!
    Silver 150 VX D4D Auto 2010
    Re: New Key Needed... $400
    I was talking to the boys at Mr Minit the other day, yes $400 is cheap from what i can gather, they tell me toyota is three times the price.
    [b]Rob[/b]
      What about on fleabay? I recall that soemone picked up a key for a 120 off fleabay for less that $100. They just needed it cut and coded which I believe they had done for a relativerly good price, well under $400.
      [COLOR=#000080]Nick[/COLOR]
        The $400 was from the dealer... It' a grand if you lose both with their coding for a single new one!
          50% inflation! Just got a quote for a new key and it is $615! how can these guys (toyota) justify it?
            I organised a 3rd key from and alternate car manufacturer, they charged $260 and required all three keys to sync them to the same code sets
              How do I find this mob? was this for the current model Prado?
                This was advertised here as cheapest Toyota Keys:
                http://www.allkeyedup.com.au/shopdispla ... =Key+Cases
                2011: 150 GXL D4D: Redarc brake controller,UHF, Couplertec, Thurle bike racks, 3rd row seats removed..DIY locker installed, Maxtrax, Staun tyre deflators, Dual battery, 74lt S/S National Lunar, Airbags. DP Chip..magic.
                Ultimate Nautilus #23 on order.
                  Consider $400.00 is about normal for modern "smart keys", Holden, Ford the same, think BMW/Mercedes/Audi, now your serious at $800.00.
                  Regards, Richo.
                    I suddenly feel like being a bit more careful with my keys. I have seen some silicone key covers for some other brands. Has anyone seen any that suit the 150 keys?
                      i had to get a key for a barina, so bought 1 off ebay (cant remember accurate prices but around $10 for flip out style) then took key to local hardware who first cut a standard blank, used that to test it worked in door then tried ignition. it will fit and turn over engine if it is cut correctly. they then knew the blank was cut correctly and cut the new flip out i supplied. [its an expensive error to just try cut your new key blank and do it wrong. they say all care but no responsibility. be careful!] I then bought the electronic module bit for inside blank from 1 dealer who was the cheapest after many calls and then took same key and module to another local holden dealer who programmed it for around $40-50. it was definately under $100 this way. also the hardware gave us the steel blank so daughter had a spare just to open car in case she ever locked rest of the keys in it, cheers
                      [size=1][color=#990000][b]--> Macarthur District 4WD Club Member <--[/b][/color]
                      ::2005 Black Grande Petrol V6::2 x PP Stickers::ARB Deluxe Winch Bar::IPF Spotties + Fogs:: Dual Battery, ABR DBi120 Isolator & Volt Monitor::ARB Portable Air:: Rear Drawer Unit::Trek Table::WAECO 40Lt::WAECO Raps R12U::AMTS Rear Tyre Spacer::HILUX Washers::UHF::Prodigy P3::Stebel Air Horns:: Inverter::CouplerTec Electronic Rustproofing::OEM Roof Racks, Towbar, Hard Wheel Cover::REAR CAMERA to factory GPS::[/size]
                        I live in Nairobi, Kenya and drive a 2003 Toyota Prado TZ imported from Japan.
                        The key with the "L" on it cracked when I started it. I crazy glued it back together but have purchased a new key(with a circle on it) for about 5,000KSH($50) from Toyota East Africa. I didn't buy a new black key(with an "L" on it) because it was selling for 33,000KSH($330).
                        I have had the new key cut. I tried to start the engine and no luck. The chip must be recoded. Toyota wants close to 10,000KSH($100) to do it.
                        I heard there is a way to code the key in the car using the brake pedal and gas pedal.
                        Does anyone know if this is possible?
                        If so, has anyone done this in their Prado?
                        Thanks,
                        Zamy
                          Zamy,
                          Check out this link. It is a way of reprograming the chip for the 90 series (it worked on my 90 series) not sure if it will work on your model.
                          http://www.lcool.org/technical/90_se...ansmitter.html
                          Badhabit
