Dash vibration when engine lugging ....
    Re: Dash vibration when engine lugging ....
    Hi Folks
    Haven't noticed these problems on my 150, V6
    Richo
      My V6 is fine too. Can't work out why it's a transmission issue if the V6 doesn't do it. Do they run different transmission firmware in the different engines? If so, can the V6 transmission firmware be installed on the D4D?
        Double post.
          Different engine types need different shifting points for their tranny's to transfer the drive correctly to the wheels. All diesel engines vibrate more than their petrol equivalents, its just the way they are. If you don't like the vibration buy a V6 and get ready to use much more fuel.
            I have had no lugging at 1500rpm since I installed a Steinbauer chip a week ago. Better power and no lugging!!
            Ken
            2010 150 D4D Kakadu, Graphite, Toyota tow bar, Tint, Mats, Headlight Protectors, Redarc dual battery and Brake controller,Sahara Bar,Safari Snorkel,Icom440,OME suspension,Steinbauer module,Genesis HID lights.
              I have the vibration in my 150 TD GXL auto too. Its on the drivers side now after the dealer did a pillar guard adjustment on the Passenger side but now I have it on RHS. What in fact did your dearler do to get rid of the vibration. Thanks
                Do you know what the dealer did to get rid of the vibration? Thanks
                  They can't fix the vibration its inherent to the model (unfortunately) only the rattles can be fixed (temporarily). My dealer has now given up and said they can't do any more with the dash rattle.
                    Riv39
                    I have a rather annoying rattle on the right hand side and it appears to be in the dash. I found it was the bonnet rubbing so I tightened the rubber height adjust blocks on the leading edge of the bonnet. But the rattle returned after they fitted new head lights (filled with rain water). The rattle is most present at low revs and also on the highway with bumps. I have not as yet found it but for some reason the rattles in the 150 appear to come from a closer location. Double the distance from where you think it is and you will probably find it. Might be something to do with the way the noise travels in the chasis.
                    It still rattles and drives me nuts. If anyone knows the fix please let me know.
                    Nifty.
                      The black plastic cover under the wiper blades can cause a number of different rattles and noises that sound like they are coming from the dash.
                      [B]Steve[/B]
                        So how do you fix them? I know turn the radio up or just enjoy the diesel 'signature' vibration!!
