Traction COntrol on Prado VX
  • Traction COntrol on Prado VX
    I have a new PRADO VX. Twice I have been going around a corner a little bit hard and it has felt and sounded like one wheel has locked up. My dealer says it was probably the traction control kicking in. I was not looking at the gauges so I do not know if any indicators came on but I would be a bit surprised if traction control was that sensitive. Has anyone else had examples of premature traction control? Does the dealers expalanation sound plausible?
    Re: Traction COntrol on Prado VX
    Were you turning in full lock? If so check out this thread: http://www.pradopoint.com/viewtopic.php?f=45&t=9932
    If the traction control does kick in, doesn't it beep and indicate on the dash? Or is that swerve control?
      Hmmm, premature activation ? :wink:
      Traction control is the system that keeps you going in a wheel slip situation ( mud, steep gravel hills etc )
      Stability control is the system that keeps you car stable in skids, swerves etc.
      More likely to be stability control - my 120 does it in the situation you describe.
      Cheers, Wayne
        Originally posted by ozwapet2
        Hmmm premature activation ? :wink:
        I know what they do, I'm just not sure what the indicator and annoying beeping is =p I'm assuming its swerve control though.
          In the 120 you only get the beeps when stability control activates. ( nothing on traction control )
          May be different in the 150. The manual doesn't say ?
          Cheers, Wayne
            Probably does, don't have it on hand at the moment
              Yep, my Gx has done this a couple of times as well,but only on one particular corner. Frightened the daylights out of me the first time, so much so that I nearly ran off the road.
                I've got a VX and have had this happen to me. The first time it happened i thought i'd broken my beautiful new car, what with all the beeping and shuddering. Evidently the car is very tempermental about keeping all four of its wheels touching the road.
