Home made fride slide and storage
  • Home made fride slide and storage
    Hi all
    Have been inspired by the guys doing 120 & 90 series fitouts so have started my own. It includes the following;
    1. Fridge slide for Engel 40l fridge
    2. Shelf for folding table and chairs
    Have been working on it all day and will provide photos and a list of materials and measurements if requested.
    Goodie
    photos and measurements would be good
    2011 150series GXL
      Fridge slide diagrams and photos
      Fridge slide attached with shelf to be fitted
      Slide and base in unpainted and uncarpeted form before shelf fitted
      Slide extended
      Slide detail prior to fitting front facia
        How do I add the PDF it says that over 19kd cannot be uploaded and the file is 1.09mb
          Didn't know you can attach PDFs on PP. Might have to use a file sharing site but sometimes those sites deletes the file after a certain time if you are not a paid member of that site.
            email me the file and ill host it for you
            ryan at excelerate dot com dot au
              Thanks Ryzz on its way
              Just off to buy the carpet etc
              would you all like a blow by blow re sizes, cuts and attachments for the unit. The diagram is a bit of a mudmap. I can also advise the measurements for cutting the holes to fit the false floor to make it a bit easier. (Obviously for the 150 series only)
              Goodie
                Part 1 False floor
                The false floor I elected to fit runs along the line of the fold up seats. I dont have a need to enclose the sides at this time so I left it.
                The floor is 12mm ply and to fit to the rea should be cut to the following dimensions
                1080mm x 935mm
                Note: I had all my timber cut to length at Bunnings for free. Made the job so much easier
                There are 4 cutouts to fold the rear tiedowns through.
                I will add a series of photos showing the cutouts and their measurements.
                The front 2 are 55mm in from the wheel side (to the corner adjacent the fold up seat) and 70mm from the inside of the rear plastic lip at the door (to the corner adjacent the fold up seat) I have made a cavity that is 35mm long and 5mm thick.
                  Wife has brought car home test fit photos;
                  Slide out from rear.....
                  ...side....
                  rear extended
                  Goodie
                    Fridge Slide Plan - Right Click - Save As
                      Hi all timber work finished now just for carpet, paint and securing to the vehicle......
                      Finished view front...
                      The cavity under the shelf is for a wanderer folding table with 4 seats that eventually can be a drawer. When travelling with the van a WeberQ sits on top of the shelf and when just day tripping a plastic tub with burners and cooking gear sits in the place of the weber Q. Tie downs will secure all after carpet.
                      Note I have fitted the facia so the slide is self contained so to speak.....
                      From the angle
                      Close up of front detail....
                      And now for carpet and paint.............
                      Goodie
                      Goodwinfamily
                        Just purchased the carpet from the new masters home improvement for $13 2m x 1m excellent price
                          That looks really good. I might have to build this.
                          Thanks for sharing
                          Johno
                          [CENTER][SIZE=2][B][COLOR=blue][COLOR=blue]150 GXL 2009, T/D Auto [/COLOR][/COLOR][/B][/SIZE][/CENTER]
                            Job finished photos to follow.......
                              Photos as stated
                              JOB FINISHED......
                              Painting finished (I elected to only carpet the top surfaces and paint the rest $3 per can gloss Masters)
                              Carpet on and glued down
                              another view
                              another view
