Dual Fridges
  • Dual Fridges
    Havent been able to find many people who go for dual fridge setup. I'm thinking 2x 40L Engels, giving you the option of fridge / freezer or combination of both.
    I was hoping to fit them sideways, back to back on a draw. And should leave room for the dog.
    I would like to got to dual 60s/80s and maybe slide over the 60-40 split. It just comes down to needing room for a baby seat and a small dog.
    Anyone done this? Tips? Pics?
    [B]2012 - 150 VX[/B]
    i use a 18ltr and 40ltr weaco , in my 120 .your issues will be space and battery power . search rig builds kav's booze bus .probably not what your looking for .
    kav
      two 40 litre fridges on one drawer may be a bit too much strain on a slide. I would suggest either going two side by side if needed or speak to someone like Black Widow who makes a forward floor. The Forward floor usually replaces both seats but they may do one up for you for just one side of either the 60 or 40 split seat side.
      Are you sure you need two 40s? A smaller unit for a freezer might do or one of the Waecos that have a frdge/freezer sectioned off.
      Personally you can regulate a normal fridge to the point where everything on the bottom is frozen and everything on top is not. If you wanted to do this maybe consider a 2 zone addition on top of the 40 litre.
      http://www.twozone.com.au
      _______________________________________
      [SIZE=1][B]2011 Silver 150 DVD[/B] [B]GXL[/B][/SIZE][SIZE=1], Safari Snorkel, Sand Grabba mats, Michelle Sacs seat organizer, ARB Bull Bar, Lightforce 170 HID, Bonnet and Headlight protectors, Dual Batteries, Engel Fridge, Kaymar rear spacer, Cooper STTs [B]x 6[/B], Rhino Pioneer tray in black, MaxTrax, Black Widow Drawers with top shelf, divider & cargo barrier, ARB Sports Nitrochargers and springs, ICOM IC 440N CB
      [/SIZE]
        I know I have the 120 and you are the 150 but the same principle applies. I have the 47lt ARB permanently mounted in the rear above the black widow drawers. On longer trips I remove the smaller back seat and bolt in a platform that I made to take a 39ltr autofridge that we use as a freezer.
        Some pictures in my rig build thread, and somewhere if you search you should find plans for the platform in a thread somewhere, I only found the thrread after I made mine, pretty easy job really.
          I have two 40lt Engels on blackwidow drawers in a 150 they fit well and heaps of space running one as a fridge the other as a freezer there are a few more pics in my build thread
            Just what i was saying Same principle, take the smaller seat out if needed or 2 40s side by side like thyswyup. Reckon you need some storage somewhere else though.....trailer maybe?
            [/SIZE]
              I use the engel 57 combi fridge and freezer. Kills both birds with the one fridge
              SOLD!!! 2011 Prado GXL manual in silver
              ARB Winchbar, Lightforce HID's, 3" SS Manta exhaust, 3" Monster Rides suspension system, Tracklander roofrack, Ostrich wing awning, Kaymar dual wheel carrier, Gturbo stage two Grunter and reprogrammed ECU. Trackabout Dakar SV Extenda. Purchased 2017 Landcruiser 200 Altitude.
                yeah my olds have the first combi fridges they made and it rattled like hell till engel got around to working out how to fix it, but apart from that they wish they had 2 fridges, having 80L of fridge or freezer, and turning off half of it when not needed is what I'm thinking. From what i have read you can fit 60cans in the 40L??
                Bob
                  How would these have been hooked up for power and would thswyup had an alternate power supply to keep fridges topped up. I am thinking of doing this myself just for travelling, no off road
                  A Happy Camper
                  Carey
                  Nov2012 Kakadu D4D auto,Toyota bar, IPF900xsHID, ARB/Redarc SBi12 Dual battery, diode,UHF3540, Provent style oil catcher.
                    I am not sure what THSWYUP. Has done but I just wired 2 plugs for my 2 fridges instead of one. I don't have solar or a generator, just charges of the alternator. If you are stopping for long periods without driving then solar or some other auxiliary power might be needed.
                      What sort of time/days would I get out of 2 x 40cfx if staying a couple of days somewhere then back on the road again thanks? I have dual batteries being the standard main battery and a 90a/hr aux which is a deep cycle one. I have searched on here but everyone seems to have either different setups or plug in solar etc and I cant seem to work out what I need. Have even been thinking of just stopping some where for a couple of days near a pub just in case the fridges don't last long enough
                      A Happy Camper
                      Carey
                        There are so many variables as to how long you would go, what temps you run your fridges at, how often do you open them, are you adding warm drinks or not, what other accessories you run, ambient temperature, parked in the shade or the sun?
                          no worries thanks anyway cheers
                          A Happy Camper
                          Carey
                            Probably the easiest thing to do is give it a try at home, set things up as you might on a trip and run the fridges and monitor voltage levels over the course of a day or 2, it will give you a good indication. In my case usually I can go 24hrs without putting in much charge with 1 fridge and 1 freezer, after that I need to start the car or add power, we rarely stay put for that long so never had an issue.
                            Another thing I do to help is that I have outlets that I can plug into from both the auxiliary and the crank battery. On our recent trip when we had not moved a lot for a few days and the batteries were getting low I would change them to the crank battery shortly before driving, I figure I have plenty of spare amps in the Alternator and the auxiliary will recharge quicker as you are not drawing current from it while trying to recharge it.
