G'day racor,
PM him mate with the following info:-Ordering info:
Send an email to tinhua.tnn at gmail dot com
Subject: PP username 150 Bash State Postcode (eg Tin175 150 bash QLD 4300)
cheers,
chappy.
Odd, My Bilsteins came with stone guards with them from supplier, did you not get any supplied?
Mine did not.
a question concerning the fitting of the shock guard for those who have already fitted them,did you raise the vehicle of the ground so that the suspension had no load on it?,my concern is stored energy with the shock when I go to unbolt the bottom mounting bolt to fit the guards as I don't want risk being taken out by the shock when I start fitting the guards.
cheers.
Left mine on the ground as well, just remove the bolt that holds the washer in place, it is not actually holding the shock, the shock is on a metal rod, that the bolt threads into. There isn't even any need to remove the wheels to fit them.
2015 GX Prado 3L Auto, in the process of being fitted out.
Cheers for that fella's,I've not played with suspension components before and wanted to play it safe.
Looks like I got alot of tins gear to fit this break!.
