Hi All,
Must have too much time on my hands, but based on a few other threads I started seeing if it was possible to retrofit the ECO/Sport Driving Mode, Crawl Control and MTS functions to my Nov 21 VX Prado.
I probably don't need all of them as I mostly do touring trips towing a caravan with a bit of off road and beach driving along the way but thought others may be interested in the topic and doing the mods if it is feasible.
Firstly the easy one ECO/Sport Driving Mode which I am in the process of doing as soon as the part arrives:
But at least it indicates that the change-over of the dash centre console switch panels from standard VX to the VX-L (Kakadu) version with Crawl and MTS is relatively simple and uses the existing harness connectors (not certain if the harness on the GXL is exactly the same).
Parts required (needs to be confirmed as correct and if there is anything missing):
Activating Crawl Control appears to be easy and varies from works straight away, or requires an ABS/VSC/TRC system memory reset/test to be conducted using Techstream.
Activating MTS seems to be a problem depending on which configuration of the Brake Actuator Assembly (Skid Control ECU) you have fitted as some earlier revisions appear to need the KDSS ECU fitted to work. But there seems to be promising info for me at least that the Jul 21+ VX is OK and may only need configuring using Techstream.
I had a look at the wiring diagram and the combination switch assembly appears to be very basic switches connected via the harness connectors to the Brake Actuator Assembly in the engine bay.
So if you only wanted a single speed/mode crawl/MTS then it could potentially be done with aftermarket push button switches and links to select which one you want (defaults to position 3 medium crawl and mogul if you do not add links).
Still early days but I thought I would put out there now to see if anyone else has tried this and start a conversation to come up with working solutions.
Cheers Phil
- This is a simple upgrade by the addition of the OEM switch panel in the console attached to the existing wiring harness (or you can do an aftermarket version if you don't want to spend the approx $100 to get the OEM switch)
- Confirmed to work on VX but still waiting on verification for GX/GXL/GXL+.
- This is covered off in detail in this thread Sports mode for non-Kakadu models - Toyota Prado How To's, Technical Information & Reviews (pradopoint.com.au).
- On what is the difference between the blocks of MTS 2 restyl – Toyota Land Cruiser Prado 150-series, 2.8 liters, 2018 | Surveillance | DRIVE2
- Still, I activated it. Installation and activation of MTS panel. - Toyota Land Cruiser Prado 150-series, 2.8 hp, 2016 | WITH YOUR OWN HANDS | DRIVE2
- SWITCH ASSY, COMBINATION 8497060330 (VX-L/Kakadu version which includes two redundant air suspension switches), or
- SWITCH ASSY, COMBINATION 8497060350 (listed in the parts catalogue as VX version without air suspension switches but may be difficult to source)
- PANEL SUB-ASSY INSTRUMENT CLUSTER FINISH CENTER 5540560580 (small glovebox fitted below switch panel)
Cheers Phil
