I have booked the car for Saturday to have the bilstein raised drivers front I can't be fussed trying to crack the valves etc and the more I read the more I think the spacer or higher cir clip setting should permanently level it out. I just hope raising one side front 8-10mm is enough to raise the rear 20mm ?
Fixing KDSS lean after lift query..
Head out to the garage and go to the drivers side front corner (level ground) and push it up by 10mm, you will see you rear passenger side corner drop by 10mm and your car 'should' be level. Makes it easier with a bar on it to pull up but you should be able to find a point to push up from and get your wife to stand at the rear and watch the difference. 10mm was all mine needed, 15mm was to much. You should be able to fix your wheel alignment and steering wheel being out of alignment with that spacer as well.Originally posted by KAKADAZ View PostI have booked the car for Saturday to have the bilstein raised drivers front I can't be fussed trying to crack the valves etc and the more I read the more I think the spacer or higher cir clip setting should permanently level it out. I just hope raising one side front 8-10mm is enough to raise the rear 20mm ?-----------------------
Daniel
How much lean did you have? I just measured mine and found it's 20mm lower front ant rear drivers side being lower. I think my Bilsteins have the cir clip at the lowest of the three settings so I can raise the front strut 8mm or 16mm? Tough one. And it is being wheel aligned after their done with it.Originally posted by Rogerthatv2 View PostHead out to the garage and go to the drivers side front corner (level ground) and push it up by 10mm, you will see you rear passenger side corner drop by 10mm and your car 'should' be level. Makes it easier with a bar on it to pull up but you should be able to find a point to push up from and get your wife to stand at the rear and watch the difference. 10mm was all mine needed, 15mm was to much. You should be able to fix your wheel alignment and steering wheel being out of alignment with that spacer as well.
Thanks heaps for your advice Dan it's good to have someone a few steps ahead of me playing with the same things.2010 Kakadu with all the usual stuff.... Build up thread below
Mine was 25mm out and I just checked it, I still have a 10 mm and 5mm spacer in it. I removed the 10mm as I replaced the front coils as we also thought they were he issue. Easy done on the help mate, I know what it is like to have this issue.-----------------------
Daniel
So just a 5mm spacer at the moment and it's leveled out the 25mm?Originally posted by Rogerthatv2 View PostMine was 25mm out and I just checked it, I still have a 10 mm and 5mm spacer in it. I removed the 10mm as I replaced the front coils as we also thought they were he issue. Easy done on the help mate, I know what it is like to have this issue.2010 Kakadu with all the usual stuff.... Build up thread below
Thank you Sir I may go the 16mm. Option on mine the not sure 8mm will do it.Originally posted by Rogerthatv2 View PostSorry o, I had 25mm in and removed a 10.2010 Kakadu with all the usual stuff.... Build up thread below
I think that should be fine, as you will notice when you pull upmon the drivers side front corner it will push down on the passenger side rear corner and it should level out.Originally posted by KAKADAZ View PostThank you Sir I may go the 16mm. Option on mine the not sure 8mm will do it.-----------------------
Daniel
I couldn't get the car back to adjust the Bilsteins but now am on the lookout for a 20mm spacer for up front.....anyone know who sell them??Originally posted by Rogerthatv2 View PostI think that should be fine, as you will notice when you pull upmon the drivers side front corner it will push down on the passenger side rear corner and it should level out.2010 Kakadu with all the usual stuff.... Build up thread below
Strut spacer? try Snake RacingOriginally posted by KAKADAZ View PostI couldn't get the car back to adjust the Bilsteins but now am on the lookout for a 20mm spacer for up front.....anyone know who sell them??
http://store.snakeracing.com.au/~sna...28fd539b23c134
Funny you say that I was just viewing their site lol. Their stuff looks good it didn't list the 150 but I will give them a call tomorrow.Originally posted by amts View PostStrut spacer? try Snake Racing
Any idea why a 10mm spacer gives 20-25mm lift?Last edited by KAKADAZ; 30-09-2011, 12:39 AM.2010 Kakadu with all the usual stuff.... Build up thread below
That's because of the geometry of the IFS. The fixing point of the strut is somewhere between the LCA pivot point and wheel hub. So there is a multiplier effect.Originally posted by KAKADAZ View PostFunny you say that I was just viewing their site lol. Their stuff looks good it didn't list the 150 but I will give them a call tomorrow.
I just had the front right Bilstein raised up one clip and the car now sits nice and level....Me much happy2010 Kakadu with all the usual stuff.... Build up thread below
Yes I'm fairly sure they removed it, compressed the spring adjusted it then put it back together and gave it a wheel align.2010 Kakadu with all the usual stuff.... Build up thread below
