Which side is higher and is it the same on the rear as well?
Fixing KDSS lean after lift query..
Passenger side higher and yes same lean on the rear just out 5mm less.
I'm back up at work now but have the exact measurements written down at home, I will get my wife to send them to me then I will post them[SIGPIC][/SIGPIC]Prado 150 , 2010 VX Diesel Auto, TJM Airtec snorkel, 2" Lift kit, King Springs, Bilstein shocks, TJM T13 steel bull bar, Tigerz 11 12000lbs winch, DP Chip, 3" manta exhaust, Light Force HID lights, dual batteries, Red Arc management, Tyre Pressure Monitor System, BFG MT 285/70/17, uniden UHF radio, LED light bar, Scan gauge 2 secondary fuel/ water separator, B&M auto trans oil cooler, 45ltr Evakool travel Mate fridge.
The Spacer is a Bandaid.Originally posted by KAKADAZ View PostI wonder though if ARB actually know the springs are different length or just use the spacer as a bandaid. If spring manufacturers knew the factory springs were un even they would manufacture theirs with a left and right with 10-12mm difference. Glad yours is all good after the alignment though mines so much nicer with the lean gone and alignment right.
I don't know why companies like ARB & Lovell's would supply these with spacers when they have the ability to simply make one spring shorter as needed. "Scratching my head"
Regards, Jason.
