When I originally put the OME lift on my 150, items such as the front diff drop kit and extended sway bar links were not, as far as I knew at the time, available. To be honest I've never found any problems with the ride, but I'm interested to know whether these items (now that they are available) are worthwhile additions? Are they now considered to be required, or just nice-to-have, or simply another way to separate me from my money??
Diff drop and extended sway bar links
Originally posted by zzsstt View PostWhen I originally put the OME lift on my 150, items such as the front diff drop kit and extended sway bar links were not, as far as I knew at the time, available. To be honest I've never found any problems with the ride, but I'm interested to know whether these items (now that they are available) are worthwhile additions? Are they now considered to be required, or just nice-to-have, or simply another way to separate me from my money??
The rear links are still in development for this model & will help to reposition the swaybar back to a better working position after a lift.
Regards, Jason.
Don't own a 150 but hope it helps. This mob appear to do a lot of nice stuff!! I'm no expert though...just giving you a link...hope it helps:
http://www.superiorengineering.com.a...10_923_981_993
Cheers[SIZE=1]03 TD 120 Grande, L&R weathershields, f&r deflectors, Sov bar Amts rad b.pl, TJM front B.P, Uniden UH7760NB Kaymar LED worklight, ARB 47l, lifestyle rack & Milford C. Barrier, 9500llb Superwinch, IPF 900SR spots, T. Dog 40mm adj shocks/struts, coils, airbagman OA6011 airbags, 2.75" Beaudesert exhaust, 300w inverter, 1L Catch can,outback rec points, R.R awning, dual batteries redarc SBI12 Cooper LT A/T3's 265/65, Safari snorkel, Hilux jets, Brains TG150, Leigh's booster diode [/SIZE]
A diff drop kit will actually reduce clearance under the front, so unless you are lifted over 2" and CV binding is an issue then they will be a step backwards.
As for rear swaybar links, If the sway bar is not the limiting factor in suspension travel then a slightly longer link might neaten it up and give slightly improved wear on the rubbers. On the flip side, when I fitted longer shocks to my 120 and as a result extended the sway bar links to improve articulation the longer links made handling on road a bit worse. Nothing major, just a little bit more body roll. I was happpy for the slight trade off in on road handling for the improved wheel travel off road. So once again if wheel travel is not limited; extended links might reduce handling without any improvement elsewhere.
Originally posted by AJ120 View PostA diff drop kit will actually reduce clearance under the front, so unless you are lifted over 2" and CV binding is an issue then they will be a step backwards.
I would like to try extended rear sway bar links, but I don't like exposed heim joints in a wet and muddy environment. Maybe I'll cut and lengthen an original Toyota set....
Originally posted by zzsstt View PostI was thinking the same thing about the diff drop!
Originally posted by zzsstt View PostThat looks like the way to go.... Did you put a left hand thread on one side so you can adjust without loosening the ends?
I set them 30mm longer than standard, that gives me full flex with my longer shocks, neatness up all the angles even at full flex and I haven't adjusted since. Only takes a minute or 2 to adjust them if I wanted.
