Softer suspension?
  • Softer suspension?
    Hi All,
    I have a 150 GXL (d4D) and has clocked 62K km.
    Enjoyed it (and warranty ended), and now wondering anything I can put in to get a much more comfortable suspension (and ride)?
    Originally posted by wazafi View Post
    Hi All,
    It should already be comfortable.
    Not sure what you are looking for.
      I found that adding my 2 inch lift made the ride more comfortable on top of the increased height. Stopped the double bouncing going over speed bumps etc.
      Not sure if you wanted a lift as well as improving ride but I like mine.
        Any softer and it would be a bean bag, so I'm assuming you want to reduce the body roll and nose diving under braking? If so, new springs and shocks plus tyres with stiffer walls will help.
        You're in Perth so I recommend Malaga Suspension are the ones you want to talk to, they know Toyotas
        2011 Upgrade V6 GXL Graphite, Optima Yellowtop/Redarc Dual Battery setup, Dobinsons/Bilsteins 2inch Lift, Rhino Pioneer SXB Tray, Foxwing Awning/Tagalong
