Originally posted by setsujoku
View Post
Amada vs Cal off-road/Bilsten
Hi Mate, measuring the car before and after install is one thing but before you install anything you should measure the free standing height of the springs and also the closed and open (open a tad more important) lengths of the shocks and struts.Originally posted by setsujoku View PostYeah will measure everything before and after, but more just wanted to make sure that it was all the right parts!
As per most of the info in this thread, if you have open length struts of 555mm then they are hardly long travel being the same length as the stock struts... they will be absolutely useless for a 3" lift and highly questionable even for a 2"lift.2010 GXL V6 - Point Cook, Victoria
Gavin
I just installed a standard 712 Bilstein strut with some Roadsafe HD strut tops and got some good measurements.Originally posted by zerosecta View PostAs per most of the info in this thread, if you have open length struts of 555mm then they are hardly long travel being the same length as the stock struts... they will be absolutely useless for a 3" lift and highly questionable even for a 2"lift.
While the Bilstein shock has a 555mm open length, when assembled with these strut tops the assembled strut measures 570 from the mounting face of the strut top to the centre of the lower mounting bush.
I'm getting,
790mm (40mm lift)
885mm max extension giving 95mm droop.
If I did a 3" lift (75mm) this setup would still give me 60mm droop which is OK. I also checked the closed length geometry and I still have about 20mm before bottoming out the shock.
Some pics and more info in this thread.
http://www.pradopoint.com/showthread...-120-IFS/page2
Hey tin,
Could you post a photo or url for the Roadsafe strut caps?
Best
http://www.pradopoint.com/showthread...l=1#post503720Originally posted by Whitey View PostHey tin,
Best
Mark
Whitey
