I thought there would be others out there with similar story :-) feel both bad and good at the same time about it... You do start to feel after a while like it is you that is just being difficult.
BEWARE!! dealing with CalOffroad
Originally posted by christofurry View PostRim to guard 810mm wheel on the ground
Rim to guard 915mm wheel off the ground
Very interested in your 910mm messurement...
I guess iether you have their 595mm Length Strut or simply different rims can vary the results??2010 GXL V6 - Point Cook, Victoria
Gavin
Originally posted by zerosecta View PostJust a qiuck point...
The extra 20mm Length strut gave me an additional 30mm of droop.
So I guess tht would indicate a ratio of 1:1,5 when trying to calculate how much travel\sag etc you can get with varying strut open lengths.
I believe you said in the Amada vs Bilstein thread that your original droop measurement of 20mm was an approximate one.
I would be very surprised if the leverage ratio on the 150 IFS is not the same/close to the 120.
On the 120 series, it is 1:2.2 for strut travel vs wheel travel.
Anything lower than 2 is usually bumpstop closure gap, around 1:1.5.
You can of course just measure your strut travel vs wheel travel, just get your front end up on jack stands, and from full droop, get a trolley jack and jack under the lower control arm in steps until you lift the car off the jack stands, measure bottom rim to guard and measure your strut length (bottom of washer to center ring eye).
I'd be happy to make a plot if you get the data, it would be valuable info for 150 series drivers!
Best
Originally posted by zerosecta View PostI have a 17" wheel and open strut of 575mm - my messurement from bottom of rim to gaurd is 890mm
I had cal assemble my struts too.[SIZE=1]2013 D4D Auto Crystal Pearl "Altitude" - Caloffroad Bilstein 3 inch lift, SPC UCA's, diff drop & sway bar ext. FJ Rims-ET15 285/70R17 Cooper ST Maxx. ARB deluxe colour coded bar. Lightforce 240 XGT's. Modified X9 winch, 6hp motor & 30m 10mm rope. Dual Batteries, Redarc-SBI212, Mk3 diode & custom wiring. Water watch. ARB compressor. Twine underbonnet shower. Scangauge II. Custom rear draws. TG150. Tectyle rust protection. GME 3600 UHF, AE4705 antenna. PWR ATF cooler. Genuine tow bar.[/SIZE]
Hmmm So it sounds to me like you have the 595mm open length struts from them... Unless you specifically asked for that, I'd be betting them rebuilt to 575mm - I can confirm that I have no binding at all.
Starting to sound to me like CalOffraod's R&D is infact done on unwitting customers vehicles... :-)2010 GXL V6 - Point Cook, Victoria
Gavin
Different diameter rims will not change your droop result, as it's just subtracting one figure from another, but if chris is running something higher than 17's, then just take his 910mm measurement and subtract 1/2 of the difference in rim diameter to get it standardised back to 17" rims. eg, for 18" rims, 910-(0.5*25.4) = 897.3mm for a 17" rim.
If chris has a 595mm open length strut, then applying the difference in leverage ratio means (595-575)*2.2 = 44mm extra in wheel travel as measured on the outside of the rim.
So compared to your 890mm measurement, chris would be at 890+44 = 934mm for his droop measurement. Even if the leverage ratio were 1.5 (which I still doubt), then he would have 920mm at full droop.
The easiest way to tell is for chris to jack his Prado up and get the wheels at full droop and measure the open length on his strut.
At the moment, I doubt chris has 595mm struts.
Best
Hey again zero and chris,
I've added a bit more scale to my original lift vs droop plot for 120 series, and added your data to try and get an idea of what open length chris might have;
For zero's case (i) and case (ii), you can see that the lift of over 3.5" is the real culprit behind the limited droop. zero, if you can lose 30mm of ride height on the front, your droop will improve to around 80mm.
Bearing in mind this plot uses the 120 series leverage ratio (1:2.2), and that the 150 series may be slightly different, it suggests chris has something like a 582mm open length strut.
...but hold the phone, I've just looked at the photos in post #91, and chris is running FJ Cruiser rims, which have a different offset to 150 series rims, so chris has a longer leverage ratio due to the bigger offset of the 150 rim (ET15 for FJ, ET25 for 150, meaning FJ wheel sits 10mm further out giving longer leverage ratio).
I now believe chris has a 575mm open length strut, and his excellent droop of 105mm comes simply from his much lower ride height of 810mm, and a slightly longer leverage ratio.
Hopefully chris can confirm this soon.
Best
Mmmm.....Thought I should go and check mine.
I have TJM Alloy Bar, second battery and Brown Brothers under body protection. Dobinson c59-296 springs supplied by Caloffroad.
Ride height with spring circlip third groove from the bottom of the strut 800mm.Ideally slightly longer length spring would be good giving a better scope of ride height either way. (Beggars cant be choosers)
Droop measurement the same as yours Zero 890mm.
I am also only running the stock upper control arms and I have positioned the coils on the strut in such a way at full droop the upper control arm doesn't hit the spring and fits nicely between the coils. Probably doesn't give me much more but I like the idea it will not hit the coil.
Rear springs Dobinsons c59-325 ride height 820mm.
Fuel gauge showing three quarters full and ARB Drawers fitted.
Hope this info helps somebody.
I thought I should put back where I could, as I have learnt a lot and are still learning from other members posts.
Hey again,
If this is true and chris has a 575mm strut, then it begs the question why has CalOffroad sent chris a 575mm open length strut in the first place, and then sent zero a 555mm strut??
Chris, did you specifically ask for a 575mm strut?
Best
Hey Bushki,
So you have 90mm of droop at 2" lift, which suggests you have the 575mm open length strut.
Any chance you can measure your strut open length at full droop, bottom of washer to center ring eye.
Best
Hey again,
Plot updated to include the measurements from Bushki;
Another thing to keep in mind is the thickness of the shroud spacer, which will add to the open length. On the older 712's, the shroud spacer was around 8mm thick, meaning open length = 553+8 = 561mm. I haven't had a chance to measure the new spacer that goes with the new convoluted boot on the newer Bilsteins.
So it's possible Bushki has another variant of the strut with a slightly shorter open length, say 565mm, which with the shroud spacer will give over 570mm.
Hard to say without exact strut measurements, but it seems CalOffroad are sending out different open lengths to everyone.
Best
