Trial and error.
Keep adding until you get the lift you desire.
Kakadu suspension upgrade - any successes?
Guest replied
How many mm of spacers are guys putting in to achieve desired lift ?
Sent from my SM-G925I using Tapatalk
Leave a comment:
Guest repliedSorry, my crystal ball is broken. What did you do?Originally posted by slipperyskakadu View PostHey Amts my drivers rear seems to be on a lean ?
Leave a comment:
Leave a comment:
Thanks Amts, I got 8mm spacers in their. Gave me 20mm lift. What's everyone doing ?
Leave a comment:
Guest repliedIt's the same as for the 120. Space down the height sensor with washers.
Leave a comment:
Can anyone tell me how I trick the rear airbags on the 150 kakadu please ? any photos ?
- 1 like
Leave a comment:
Hi winstonwolf , in Brisbane you could call zordo or pm him. He is a forum member . I believe Aussie Andy has installed the cal offroad gear with king springs so you could pm him to ask about pros & cons as he's very knowledgeable & helpful
Cheers Matt
Sent from my SM-J110F using Tapatalk
Leave a comment:
Guest repliedExpensive paper weight...
Leave a comment:
Guest repliedZero ripped the lot outOriginally posted by Piggy View PostDifferent service to this one: http://www.pradopoint.com/showthread...ght=caloffroad
Anything ever come from this Zerosecta?
http://www.pradopoint.com/showthread...-adjuster-kind
Leave a comment:
Guest repliedDifferent service to this one: http://www.pradopoint.com/showthread...ght=caloffroad
Leave a comment:
The front is 793mm drivers side and 800mm passenger side.Originally posted by amts View PostWhat is the current suspension height and droop measurements?
The rear and Neutral height is 830mm drivers side and 820mm passenger side.
High setting
870mm Drivers rear and 855mm passenger side. This is measured from the bottom of the rim to the underside of the wheel arch through the centre of the rim. The front remains the same.
I've been told to adjust the KDSS on the prado it's slightly different to the 200series. Instead of jacking the body higher on the low side with the bleed valves open, you actually jack the high sided axel into the wheel arch with the valves open then tighten. I'm told you can get it within 5mm or so. Otherwise Toyota can attach the pump and add more fluid and reset the level at my next service.? Will give the jack a go first.
Leave a comment:
Guest repliedWhat is the current suspension height and droop measurements?Originally posted by Orrsom View PostCal was a great help for me. Email, phone or text response to all questions. He told me to get the installers to call him direct if they had any issues or questions. So purely from my experience, I would not hesitate to recommend them. Just my two cents.
Leave a comment:
Guest
Guest
Guest
Guest
Guest
Guest
Guest
Leave a comment:
