Fitted Lift Kit
  • Fitted Lift Kit
    I plan to have my lift kit done next week followed by the new BFG 275/65 R17 AT's @ $318.00ea
    I have had numerous quotes and am yet to decide the final installer.
    Supplier No 1: King springs, Bilstein Shocks, Poly airs, Fitting and alignment $1645.00 (40mm Lift - can't won't do a 50mm ?)
    Supplier No 2: Pedders 2" lift including Pedders springs, shocks, poly bags and alignment $1725.22
    Supplier No 3: King springs, Bilstein Shocks, Poly airs, Fitting and alignment $2350.00 (50mm Lift)
    Any advice ? I looked at OME and was advised the King spring and Bilstein combo is better. Why does the one supplier refuse to do a 50mm lift ?
    Regards Derek
    Prado 150 GXL - V6 Auto, ABR-SIDEWINDER Dual battery System, Tekonsha P3, 50mm Lift kit - King Springs & Bilstein Shocks, Polyair Bags, BFG 275/65R17 Tyres, Milford Cargo Barrier, ERPS Extreme use 10 coupler rust protection, Rhino Rack, Factory Towbar, ABR-SIDEWINDER fridge/freezer, ABR-SIDEWINDER compressor and PSV deflators, Twin Drawer system, Fridge Slide, Twin 23L water tanks, 80W Solar Panel, Hot Water Shower, ARB Awning, Toyota Seat Covers, ARB Winch Bar, Warn XD9000, HID's, Snorkel .
    My website: [url]http://www.sidewinder.com.au/[/url]
    Re: Lift Kit
    Lift kit and tyres now fitted
    Very happy with the price and final result.
    Tyre size 275/65R17 still fits under the hard cover
    The data:
    Front: 885mm -> 945mm = 60mm
    Rear: 902mm -> 990mm = 88mm
    Diff Centre: 226mm -> 247mm
    King Springs RR
    Bilstein Socks
    Polyair Bags (2 bar)
    BFG AT 275/65 R17
    Fuel +-90L
    I think it should settle well after winch and drawer system is fitted.
      Re: Lift Kit
      some decent suspension and new rubber certainly add to making it a better looking vehicle. cheers samo
        Re: Lift Kit
        Nice looking rig! Can't wait to see it with an ARB Deluxe bar
          Re: Lift Kit
          That thing looks nice!!!!
          seems a bit nose heavy. Were the springs and shocks model numbers the same used for 120 lifts?
          cheers
          J
            Re: Lift Kit
            cheers
            J
            Yes same kit as the 120 Prado.
            It will settle, the Polybags have 2 Bar which is lifting the back a bit and once the tanks are full, fridge and drawers fitted it should be good.
            I will take it for a run this weekend with a bit of a load and lower the pressure in the polybags so they are not lifting the car.
              Re: Lift Kit
              Hmmm, I'm starting to think that my first impression may be wearing off and the modified 150 is really starting to grow on me.... A LOT!
              Looking very good there ABR, and I'm looking forward to seeing some bar work on it now.
              Could be time for you to start up our first 150 Series Rig Build-Up thread 8)
              Keep up the good work and updates.
              AJ
              [i][size=2][color=#008000]2008 D4D GXL Auto [/color]- [u]BLACK[/u][/size]
              [size=2][color=#0000FF]- ARB Deluxe Bullbar - TJM Airtek Snorkel - Pirhana Dual Battery - BFG A/T's - Waeco 60L - Canvas Seat Covers - LED Spotties - Bilstein/Ridepro Lift - TJM Bashplate - GME TX3440 UHF - Rhino Roof Bars - Rooftop Tent & Awning - Poly-Airbags - ScanGauge II - Beaudesert 2.75" Exhaust - ARB Twin Motor Compressor [/color][/size][/i]
                Re: Lift Kit
                I had a play with photoshop, kept the roof line level.
                The 120 & 150 Prado are very close in size, shape etc.
                  Re: Fitted Lift Kit
                  Nice! On a minor detail of your cool rig...is the hitch a factory option or did you have it installed? Here in Riyadh the dealer as of yet doesn't have a hitch option for the VX-L available yet. Ideas on how I might be able to add one would be much appreciated!
                    Re: Fitted Lift Kit
                    Looking good mate. What were the Kings Part numbers? Which of the 3 circlip positions on the bilstein struts was used?
                    I've just ordered a VX D4D and plan to lift it straight away.
                      Re: Fitted Lift Kit
                      It was fitted the day I collected the car. It is a Toyota option with Toyota tag.
                        Re: Fitted Lift Kit
                        KTFR-101 and KTRR-102 with poly bags. Clips should be in top groove as bar and winch still coming, I did not see the fitting but based on the height and ride I would say they are.
                          Re: Fitted Lift Kit
                          ABR - SIDEWINDER - Thanks - I just wish the dealer here in Riyadh was as convenient. The Prados here are sold the way they arrive and so far they offer no accessories for 2010 :cry:
                            Re: Fitted Lift Kit
                            Cool. What height is the rear at with 5psi in it?
                              Re: Fitted Lift Kit
                              It is loaded now with drawers, fridge, 3 chairs, table, milford barrier, shelf, compressor and odd recovery bits.
                              Rear: 965mm
                              Front: 950mm
                              Regards
                              Derek
