Kakadu Rear Airbag Hight sensors
    Not sure which strut you have but the bottom notch position usually replicates the position of the factory lower spring seat.
    The height adjustment is close to 2:1 ratio. Notch separation is normally 8mm, so moving it down 1 notch will be around 16mm lower in suspension height.
    What is the part number of the front coils? Are they KDSS specific coils (i.e. uneven length)? If they are not KDSS specific coils, then the notch position needs to be different between driver's and passenger's side. Driver's side needs to be 1 notch higher.
      They are as follows:
      Bilstein Front Shocks: B6 (B58712)
      Bilstein Rear Shocks: B6 (24 238830)
      Dobinsons Front Coils (100kg) (C59-726) (KDSS specific)
      [B]2009 150 D4D Kakadu[/B] | Ebony Blue | TJM Winch Bar
        Where are the sensors?
