WOW? I just asked for the factory replacement size! As the Diameter is 776mm. I think the 275's are 846mm? I didnt want to blow out the speedo too much. I had so many hassles with the Grande that I dont want to do the same with the Kakadu?
Who has upgraded their Tyres on a VX or Kakadu?
Originally posted by mickmac_42 View Post275/65/18 should be around 815-820 (a little over 32") depending on the tyre.2010 Kakadu with all the usual stuff.... Build up thread below
Originally posted by WOLF View PostWOW? I just asked for the factory replacement size! As the Diameter is 776mm. I think the 275's are 846mm? I didnt want to blow out the speedo too much. I had so many hassles with the Grande that I dont want to do the same with the Kakadu?2010 Kakadu with all the usual stuff.... Build up thread below
Originally posted by KAKADAZ View PostI have read somewhere on here the speedo can be re calibrated by Toyota at service.
]mickmac_42 is rite the 275 65 18 is just bigger then a 32' and the speedo can be recalibrated but with these tyres shouldn't need to be as they run 3 to 4% over. other members that have already fitted them state this is correct also.
[ATTACH=CONFIG]7028[/ATTACH
on a KMC 18x9 +18 offset. no scrubbingLast edited by stewydz; 13-08-2012, 01:20 PM.2010 Kakadu T/D, Auto, Sahara bar, HID IPF 900s, Beaudesert Exhaust. 2' Bilstein lift, Steinbauer chip, rally X mudflaps, kaymar rear door getup, Cooper AT3 275 65 18 on KMC wheels and bfg km2 285 70 17 on dick cepek torque, safari snorkel, ARB roof rack, dual batts, uhf and brake controller and a bit of other crap.
If that doesn't work you could always try this http://www.yellr.com/yb_home.htm
MikeMy build [url]http://www.pradopoint.com/showthread.php?25816-Mikes-150VX-Yes-it-s-another-silver-Prado[/url]
Originally posted by stewydz View PostWolf i would recommend shopping around. I got a set of the cooper AT3's 275 65 18 with kmc wheels on the way from a mob in sydney to my door better then they could do. will post a pic once fitted.
what was the name of the place in sydney?
Originally posted by Lindsey Mclean View Posthi stewydz,
what was the name of the place in sydney?2010 Kakadu T/D, Auto, Sahara bar, HID IPF 900s, Beaudesert Exhaust. 2' Bilstein lift, Steinbauer chip, rally X mudflaps, kaymar rear door getup, Cooper AT3 275 65 18 on KMC wheels and bfg km2 285 70 17 on dick cepek torque, safari snorkel, ARB roof rack, dual batts, uhf and brake controller and a bit of other crap.
Are you talking about the same tyre in different sizes? I think the 275 looks better, will offer more scope for bagging out when pressure is lowered but it will be less fuel efficient than the 265.
Double post deletedLast edited by mickmac_42; 19-11-2012, 08:47 AM.My build [url]http://www.pradopoint.com/showthread.php?25816-Mikes-150VX-Yes-it-s-another-silver-Prado[/url]
I'm going 275x65x18" next tyre AT3's I think or ST/Maxx as a freind who is a cooper tyre seller said they're in the pipeline.2010 Kakadu with all the usual stuff.... Build up thread below
