Has anyone found a 17x7.5 ET15 rim? The closest I've found is 17x7.5 ET20 or 17x8 ET10. The problem with wider rims is that for every 1/2 inch, you need to reduce the offset by 6 to maintain the same uca clearance.
285 x 70 x 17 Will they fit?
Thanks guys. I have been running 265/70/17 for the past 4 years on my 120 (now sold) without any problems. The tyres I have used are as follows
BFG AT LT - excellent all rounder even in the mud. Very good wear 90k of mixed terrain and highway. Probably the best tyre ever.
MT MTZ - fantastic Offroad in the mud and clay. Took them off at 20k as they were getting too noisy on the road and couldn't get them balanced well on a set of speedy steels
Coopers ATR LT - they do everything well however not as good as the BFG AT on and Offroad. They were on the vehicle for 50k before I sold the car. I would expect another 30k.
The 150 is due for delivery next week and I'm considering the following (285's our out as I want to keep std 17 rims) in order of preference lowest to highest:
3. BFG AT LT 265/70/17 - guaranteed fit
2. BFG KM2 265/70/17 - guaranteed fit. Not sure about the noise and wear characteristics.
1. BFG AT LT 270/70/17 - clearance to UCA to be confirmed
Regards,
Nathan2012 GXL Prado D4D
Maxxis Bighorn 275/70/17 do fit.sigpic2" King Springs, Ironman Foam Cell Shocks. 17x9 Dick Cepek wheels with 275/70/17 Maxxis Bighorn 762S. Ironman Deluxe Bullbar. Lightforce 240 XGT Lights. GME TX3100 UHF. Scanguage II. Drifta Drawers. Wetseat Covers. Toyota. Dual Battery System. MSA Seat Organiser and Table. MSA Wheel Bin. Staun Deflators. Toyota Tow Bar. Ironman Underbody Protection Plates. Waeco CF50. Performance Chip. TJM Airtec Snorkel. Sandgrabba Mats.
Originally posted by adamr7 View PostMaxxis Bighorn 275/70/17 do fit.
I won't have the 2" king spring/bilstein lift done for a couple of months; do you know if the 275/70/17 will fit without the lift?
Dunlop specs
112S (180km/h)
Bighorn specs 275/70/17:
120Q 8 (load rating exceeds OEM; 160 km/h)
Diameter 32.2 inches
Width 11.10 inches
BFG A/T specs 275/70/17:
121R (load rating exceeds OEM; 170km/h)
Width ?
Thanks,
NathanLast edited by Nath; 05-05-2012, 08:29 PM.2012 GXL Prado D4D
Hi Nathan, that I cant answer, however, the rubbing issue is more related to the control arm than the inner guards. I dont think the lift would effect the clearance from the control arm, and therfore should fit.sigpic2" King Springs, Ironman Foam Cell Shocks. 17x9 Dick Cepek wheels with 275/70/17 Maxxis Bighorn 762S. Ironman Deluxe Bullbar. Lightforce 240 XGT Lights. GME TX3100 UHF. Scanguage II. Drifta Drawers. Wetseat Covers. Toyota. Dual Battery System. MSA Seat Organiser and Table. MSA Wheel Bin. Staun Deflators. Toyota Tow Bar. Ironman Underbody Protection Plates. Waeco CF50. Performance Chip. TJM Airtec Snorkel. Sandgrabba Mats.
Just an update my icon uca's arrived as did my dif drop kit,front sway bar relocation plates front 3/4 inch coil spacers and ome rear 10mm trim packers for extra lift.
The prado is getting repaired at the mo as i hit 2 bloody cows at the same time the other week but when i get it back i will fit all the bits and let you know the results.
Also when i drove with the 285 atz's (833 OD) i didnt notice any power loss even on the sand, felt like it actually went better
I can't wait to see what it all looks like mate. Those ICON UCAs look like a beautiful piece of kit. You should get some good travel out of that setup. Would look good flexed up on 33s.
I note superior engineering are now producing an UCA with a spherical ball joint and a grease nipple:
http://www.superiorengineering.com.a...oducts_id=8164
Definitely a lot more clearance than the stock arm. Will be interesting to see if 33s fit on stock rims with those arms fitted.
Originally posted by steelbalz View PostJust an update my icon uca's arrived as did my dif drop kit,front sway bar relocation plates front 3/4 inch coil spacers and ome rear 10mm trim packers for extra lift.
Also when i drove with the 285 atz's (833 OD) i didnt notice any power loss even on the sand, felt like it actually went better150 VX diesel. Awesome bonnet protector! Monster Rides 3" Susp Lift, 265/70/17 MT MTZ's on Dick Cepek Torques, TJM T13 bar,TG150 Guard, Airtec Snorkel, Lightforce HID's, GME TX3540, CKMTA12 compressor, redarc dual bats, Drawers, fridgy drop slide, Maxtrax, More to come... one day!
Originally posted by Winesy View Posthey guys.i put 285/70/17 on the prado with different rims and they fit alright.All i had to do was a couple of extra screws and a bit of heat from a heat gun and all is OK.
Now I know they fit i will put a set of mud tires on.
Thats fantastic news! What is the offset of your new rims? Where did you get the rims?2012 GXL Prado D4D
Originally posted by Schniff View PostI can't wait to see what it all looks like mate. Those ICON UCAs look like a beautiful piece of kit. You should get some good travel out of that setup. Would look good flexed up on 33s.
here is a few pics of amy's new mummywagon, It looks Tough as!
285/70/17's on std +20rims
http://www.facebook.com/media/set/?s...0614605&type=1[url="http://www.TEAMDGR.com"]www.TEAMDGR.com[/url]
[url="http://www.SUPERIORENGINEERING.com.au"]www.SUPERIORENGINEERING.com.au[/url]
[url="http://www.LOCKTUP4X4.com.au"]www.LOCKTUP4X4.com.au[/url]
285/70/17's on std +20rims, 3" lift, profender shocks and superior UCA's
http://www.facebook.com/media/set/?s...0614605&type=1Last edited by 1MadEngineer; 24-05-2012, 01:08 PM.[url="http://www.TEAMDGR.com"]www.TEAMDGR.com[/url]
