285 x 70 x 17 Will they fit?
  • #76
    Has anyone found a 17x7.5 ET15 rim? The closest I've found is 17x7.5 ET20 or 17x8 ET10. The problem with wider rims is that for every 1/2 inch, you need to reduce the offset by 6 to maintain the same uca clearance.
    • #77
      Thanks guys. I have been running 265/70/17 for the past 4 years on my 120 (now sold) without any problems. The tyres I have used are as follows
      BFG AT LT - excellent all rounder even in the mud. Very good wear 90k of mixed terrain and highway. Probably the best tyre ever.
      MT MTZ - fantastic Offroad in the mud and clay. Took them off at 20k as they were getting too noisy on the road and couldn't get them balanced well on a set of speedy steels
      Coopers ATR LT - they do everything well however not as good as the BFG AT on and Offroad. They were on the vehicle for 50k before I sold the car. I would expect another 30k.
      The 150 is due for delivery next week and I'm considering the following (285's our out as I want to keep std 17 rims) in order of preference lowest to highest:
      3. BFG AT LT 265/70/17 - guaranteed fit
      2. BFG KM2 265/70/17 - guaranteed fit. Not sure about the noise and wear characteristics.
      1. BFG AT LT 270/70/17 - clearance to UCA to be confirmed
      Regards,
      Nathan
      2012 GXL Prado D4D
      • #78
        The closest you'll find in a BFG AT is a 275/70/17
        • #79
          Maxxis Bighorn 275/70/17 do fit.
          • #80
            Hi Adam,
            I won't have the 2" king spring/bilstein lift done for a couple of months; do you know if the 275/70/17 will fit without the lift?
            Dunlop specs
            112S (180km/h)
            Bighorn specs 275/70/17:
            120Q 8 (load rating exceeds OEM; 160 km/h)
            Diameter 32.2 inches
            Width 11.10 inches
            BFG A/T specs 275/70/17:
            121R (load rating exceeds OEM; 170km/h)
            Width ?
            Thanks,
            Nathan
            Nath
            2012 GXL Prado D4D
            • #81
              Hi Nathan, that I cant answer, however, the rubbing issue is more related to the control arm than the inner guards. I dont think the lift would effect the clearance from the control arm, and therfore should fit.
              • #82
                Just an update my icon uca's arrived as did my dif drop kit,front sway bar relocation plates front 3/4 inch coil spacers and ome rear 10mm trim packers for extra lift.
                The prado is getting repaired at the mo as i hit 2 bloody cows at the same time the other week but when i get it back i will fit all the bits and let you know the results.
                Also when i drove with the 285 atz's (833 OD) i didnt notice any power loss even on the sand, felt like it actually went better
                • #83
                  I can't wait to see what it all looks like mate. Those ICON UCAs look like a beautiful piece of kit. You should get some good travel out of that setup. Would look good flexed up on 33s.
                  I note superior engineering are now producing an UCA with a spherical ball joint and a grease nipple:
                  http://www.superiorengineering.com.a...oducts_id=8164
                  Definitely a lot more clearance than the stock arm. Will be interesting to see if 33s fit on stock rims with those arms fitted.
                  • #84
                    pictures or it didn't happen
                    150 VX diesel. Awesome bonnet protector! Monster Rides 3" Susp Lift, 265/70/17 MT MTZ's on Dick Cepek Torques, TJM T13 bar,TG150 Guard, Airtec Snorkel, Lightforce HID's, GME TX3540, CKMTA12 compressor, redarc dual bats, Drawers, fridgy drop slide, Maxtrax, More to come... one day!
                    • #85
                      hey guys.i put 285/70/17 on the prado with different rims and they fit alright.All i had to do was a couple of extra screws and a bit of heat from a heat gun and all is OK.
                      Now I know they fit i will put a set of mud tires on.
                      • #86
                        Sorry I had to delete post
                        Winesy
                        • #87
                          Winery,
                          Thats fantastic news! What is the offset of your new rims? Where did you get the rims?
                          2012 GXL Prado D4D
                          • #88
                            here is a few pics of amy's new mummywagon, It looks Tough as!
                            285/70/17's on std +20rims
                            http://www.facebook.com/media/set/?s...0614605&type=1
                            [url="http://www.TEAMDGR.com"]www.TEAMDGR.com[/url]
                            [url="http://www.SUPERIORENGINEERING.com.au"]www.SUPERIORENGINEERING.com.au[/url]
                            [url="http://www.LOCKTUP4X4.com.au"]www.LOCKTUP4X4.com.au[/url]
                            • #89
                              285/70/17's on std +20rims, 3" lift, profender shocks and superior UCA's
                              1MadEngineer
                              Lurker
                              • #90
                                Impressed....... Very Nice Rig!
