Tyre Pressure Monitoring System (TPMS) - 2022 GXL
    Quick check on the Partsouq parts catalogue and the OEM TPMS on a European RHD 2017+ (MY18+) with 433Mhz TPMS requires:
    • 5 X In-Wheel Toyota Sensors VALVE SUB-ASSY TIRE PRESSURE MONITOR (2017- Jun 2021 P/N 4260748020 /
      Jul 2021+ P/N 4260753040 / fitting kit all P/N 0442333060 - may only be needed for reinstalls)
    • 1 X SWITCH TIRE PRESSURE WARNING NO.1 that mounts in the switch panel to the left of the steering wheel (P/N 8474650010 or subst 84746AE010)
    • Replacement of the existing Smart Key ECU with the combined RECEIVER ASSY ELECTRICAL KEY & TPMS ECU (2017-Jun 2021 P/N 897B060100 / Jul 2021+ 897B060250)
    So assuming the wiring is already there still not a plug and play addition as new ECU will require programming for the sensors and vehicle keys.
    ptommo59
      Originally posted by ratrig View Post
      Figures.
      Does Toyota sell kits?
      What TPMS kits do people recommend?
      I been using an Ebay special (~$30) since 2018.
      Change the batteries every couple of years.
        I use a 6 wheel eBay one that sits flush on my dash above the instrument panel. It reads within 1 psi of my digital gauges and hasn't needed batteries in two years
        [B]Steve[/B]
