Hey, picked up a towbar for the prado and went to fit it this arvo. From what i can see it look as if new holes need to be drilled to fit it on? maybe someone out there has the fitting instructions?? any help would be great!
Fitting Genuine Toyota H/D Towbar
Ok, can someone check there 90 series Toyota Heavy duty towbar and let me know the part number of the unit? I didn't think i would have had to drill some holes but nothing seems to line up.
Thanks Heaps
Steve2000 GXL. 3.4lt V6, ARB Sahara Bar, IPF's, foglights, 2 inch lift (OME), Cooper ST's 265/75/16
GME 3600 UHF, Nokia CK-7W car Kit
Soon to have HD Towbar and Snorkel. Maybe even lockers!
Goanna, I fitted a Hayman Reece to my 90 when I first bought it but I considered the Toyota bar too, in the end went with the cheaper option. Both just bolt straight up to existing holes though you need to remove the recovery hooks first. The only thing is that earlier models (pre 2001) did not have captive nuts in the chassis where a couple of the bolts go. The H-R came with a couple of tapped plates with wire attached so you can hold them in place while you install the towbar. If yours is one without the nuts pm me as I may still have the blocks lying around in the bits bin and you can have them for the cost of the postage if you want them.
MichaelMy 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Here is some installation instructions: http://www.westfalia-automotive.de/file ... 691101.pdf
I have also downloaded original Toyota LC90 towbar installation instructions from somewhere, I canīt remember. I can send those to you (.pdf) if you want.
-Matti[size=1]
2007 FJ Cruiser 6M/T[/size]
Thanks dieselman, the pics were great!! but im still confused, i have the right towbar, but i still don't have the right holes, the front hole is fine, but its the one at the rear, the bolt closest to the rear of the car that i don't have... going to go looking through some car yards and see what i can see. thanks again guys!!2000 GXL. 3.4lt V6, ARB Sahara Bar, IPF's, foglights, 2 inch lift (OME), Cooper ST's 265/75/16
I have Bosalīs wiring kit, made for LC90. Itīs Art.-Nr. is 006-838. It was quite easy to connect: pull wires inside to behind left backlight (you have to open left side plastic + remove rear bumper), there is a free plug for it. Just plug in.Originally posted by BAZPRADOHi Matti,
Would you have any advise on how to hook up the trailer lights? Did Toyota come up with a wiring harness for the Prado LC90 series? The dealer here does not have a clue!
Regards.[size=1]
I bought it from my local car-part-store. Cost about 40 .Originally posted by BAZPRADOWhere-o-where did you buy this Bosal wiring kit, the wiring harness I bought for the US 4Runner did not fit the OEM setup
Kinda made me mad too because it cost me $43.00..... Your help would be appreciated.[size=1]
