Redarc 52mm gauges - installation how-to queries
  • Redarc 52mm gauges - installation how-to queries
    Hi,
    Has anyone installed any of the redarc 52mm gauges? These are space-saving as there can be 2-3 gauge measurements per unit, instead of the usual one measurement only.
    https://www.redarc.com.au/monitoring-gauges-g52-eb
    Redarc mentions that it only works with their sensors. Where and how do we install their sensors? Or should the Toyota sensors be removed/replaced by the redarc sensors, which then disables the Toyota sensors and ecu connection.
    Also, does the gauge have a screw-in ring in the bezel to lock it in position in the gauge pod?
    Thanks!
    With the boost gauge you t off one of the boost pipes and the gauge has its own ECU then it has an electrical feed to the gauge. The EGT requires a welded in boss to your down pipe. The coolant gauge requires a sleeve that you set into the top hose (plenty on ebay)
      Thanks Scruffy
