Rhino Roof Racks
  • Rhino Roof Racks
    I'm looking for some 2nd hand rhino roof racks for my 2000 prado.
    can anybody post some photos of the metal leg straps, showing the profile?
    ​these are the metal plates that clamp under the gutters. I understand that for a 90 series they should be an ST2 strap on a RL110(S2) Leg.
    I would be greatful to see the profile as Rhino have nothing on their web site and some racks I'm going to look at Friday arvo on the WE have no history on what car they fitted onto.
    cheers
    Simon
    The metal strap is the same shape as the "nylon cover" that hooks around the gutter, in effect it is a 90 degree bend or close enough to 90. All the gutter mount legs have the same fitting arrangement. The Rhino fitting instructions you can download from the Rhino site gives a pretty good idea of the shape. You also get the bar length as well from the Rhino site, from memory the Vortex bars are 1375mm long.
    Where are you located? I will most likely be selling my tray and/or bars when my new Prado arrives.
      Hi Leethal
      thanks for the feedback. I am south of perth at rockingham.
      Would it be too much to ask for a photo of the strap profile, understand if too much of a pain though.
      trouble is i,ve already bought one second hand set that didn't fit and will need to sell them on, or buy just the straps. I thought that they were all the same, but they are not, i think the prado and patrol ones are similar but slighty different from each other, rhino website don't go into these details which makes things hard.
      cheers
      Simon.
        Simon, is this what you are after? they are no long on the prado but in the shed if you want more info
ID:	742146Click image for larger version
          Hi Zoc
          Thanks for the photo's, only two of the 5 came out, but the bit i'm interested in is hidden. It's the metal plate inside the legs (item 3 on the attached). This is the part that differs between models, Prado uses an S2 strap whilst Patrol uses an S5, they both look similar but are different, Rhino don't detail this on their website so I've no idea what the correct S2 strap looks like, which makes it hard when buying 2nd hand.
          Great if you are able to post a photo or two of one of your straps?
          Are you selling your racks?
          Simon
            Haha. The 1/5 was a screen Shot of the old eBay ad. Here’s some I just took. Hope it helps.
            T he metal plate sits under the gutter, id assume most gutter profiles are the same.
            If you wanted to buy them, just make me an offer. I’m new here and done want to get off on the wrong foot. It’s just shipping that may be an issue. I’m in Wollongong.
            Click image for larger version  Name:	436D58B1-0113-42BA-B4D1-217B95C9B86D.jpeg Views:	1 Size:	7.5 KB ID:	742176Click image for larger version  Name:	0A9B4AAB-CA7C-4329-9843-4E91420D9CE8.jpeg Views:	1 Size:	8.3 KB ID:	742177Click image for larger version  Name:	77B83CDB-076E-4A93-ABB1-0C79E0418B83.jpeg Views:	1 Size:	6.2 KB ID:	742175
            zoc
              Hi Zoc
              Welcome to the site!
              Thanks for the photos, that really helps and is much appreciated.
              I could be interested, but postage could be a problem, I'm south of Perth in Rockingham. If you're interested in going down this path, perhaps we can talk outside of the thread?
              cheers
              Simon
                Attached photo's of a 90 series prado rhino S2 leg strap
