Winch for ARB bar
  • Winch for ARB bar
    Hi all.
    I have a Winch compatible ARB steel bull bar on my 95 series Prado and I am looking to fit a winch before xmas.
    The question I have is that the ARB bar for this model Prado has the "W" cut out in the front of it for the WARN control box. I really can’t justify the expense of the WARN for the amount of use it will get when compared to the Premier or TMAX winches for example.
    When I went to ARB to get some quotes they only wanted to sell me a WARN 9000 due to it being "designed" around my bulbar.
    Have any of you guys fitted or seen other winches apart from the WARN in the bulbar?? If so was it just a standard bolt in job like the WARN would be?
    I am sure the control box can be mounted up between my driving lights.
    I have a feeling ARB are trying to take me for a little ride..
    Thanks in advance for your feedback.
    Ben..
    Its all in a days work for a Toyota!!
    [url="http://www.subaruclub.com.au"]www.subaruclub.com.au[/url]
    Re: Winch for ARB bar
    Hey ben
    here is a pic of mine with the 9500lb magnum winch alot cheaper than the warn.
    cheers adam
    2002 GXL 3.0ltr turbo diesel, ARB delux winch bar, 2 inch OME suspension lift, Safari snorkel, Dual battery system, uniden UHF radio, IPF HIR lights,80ltr waeco 50ltr waeco, 9500lb magnum winch, DPchip,PP stickers, custom rear drawers, power shower, rear work light, ECB roof cage, micky thompson MTZ , hilux bonnet scoop, 3" Taipan Exhaust
    [url]http://www.pradopoint.com/showthread.php?14181-adam-s-02-prado&highlight=adam's+prado[/url]
      Thanks Adam, your truck looks good.
      Was that just a standard bolt in job? Did you need any extra brackets to mount the control box in that position?
      Thanks mate...
      Ben..
        Yeah mate standard bolt in jobbie we had ARB mount it when we had the bar put on.
        cheers Adam
